banding wheels
banding wheels
Got a set of lotus Cortina steels two which have already been banded before I got them now I want the other two done wider anyone know of anyone who does this in the Norfolk area?
ELASTIC BAND
This tyrpe of mod was well before my time, but didnt they make it illegal to run banded wheels? Due to people getting silly with the width and lack of strength issues?
[img]http://img.photobucket.com/albums/10...p180311620.jpg[/img]
comming right back into fashion and I like on old cars.
Look uber wank on new!!!
PS WTF is the image code again????
http://www.bandedsteels.com/
From Retro rides;Banded Wheels Legality
« Thread Started on Nov 24, 2007, 10:54am » Some of you may recall that, in the midst of a banded wheels thread, I e-mailed VOSA for their view on the practice. The question I asked was:
I have a query about a specialist modification to steel car wheels over which there is much debate about legality.
The modification involves cutting off the outer part of the steel wheel rim, welding a band of additional steel to the wheel, then welding the outer rim back onto the band which has been inserted. The aim of the modification is to allow the wheel to accept a much wider tyre for increased grip. The welding is usually carried out by qualified welders.
Can you confirm whether there is anything within the Road Vehicles (Construction and Use) Regulations, or any other legislation, which prohibits the use of wheels which have been modified in this way?
They have now responded as follows:
Dear Mr Hilton
There are no specific regulations in the Road Vehicles (Construction and Use) Regulations 1986, as amended (C&U) relating to the type of work you propose.
Regulation 100 of C&U does require that all parts fitted to a vehicle are not likely to cause a danger to the user of the vehicle or other road users. I have attached a copy of Regulation 100.
Additionally, you will need to ensure that the wheels do not protrude from the wheel arches, or that modifications are made to the bodywork of the vehicle to ensure that the wheels do not protrude.
Yours sincerely
name removed
Read more: http://retrorides.proboards.com/inde...#ixzz1J49tII9b
Dear Mr Hilton
Yours sincerely
name removed
Thanks for the replys still don't know wot wheels to put on my motor just a couple of requirements got to b steel and got to b 13" any ideas anyone?
Adam Graham
06-09-2015 06:04 AM
