STDCi Mondeo Rear Knocking Noise
Old 07-04-2011, 08:02 PM
mike St
mike St's Avatar
Default STDCi Mondeo Rear Knocking Noise
Any Ideas Please ?
I have a 2005 Mondeo St TDCi that has a knocking noise coming from the rear, i have already had changed the rear sub frame bushes as they were U/S and rear springs because i had lost an inch or so off the end of the off side spring. We checked all the nuts for tightness on the rear suspension and checked the rear brake lines are clear. The noise only appears when i turn left onto the drive or reverse from it, a standard drop curb upto onto a flat driveway and when i turn sharply right into my road at low speed. The rest of the time it is ok, even on bumpy roads??? The noise is loud and makes me cringe, its not nice.
Come on guys any suggestions ?
Old 07-04-2011, 08:34 PM
Dal_
Dal_'s Avatar
I had a very similar noise and it turned out to be the exhaust hitting on the car's chassis hanger bracket. I got a stiffer powerflex one and it stopped it.
You can see the slightly darker patch on the exhaust where the hanger had been bashing it. Kind of under the near side rear door sort of position. I thought it was bushes at first too.
Hope it's as simple as that!
Old 07-04-2011, 08:52 PM
mike St
mike St's Avatar
I didn't mention in my first thread that the rear sub frame bushes were changed on the service, at which point the garage pointed out i had a pin hole in the pipe before the rear box. When i took it back to further investigate, only a week later, the exhaust was hanging off and we thought that was the noise. It was replaced with an original back box but the rubber wasn't. I certainly think this is worth further investigation. Maybe thats why the exhaust broke through so quickly???
Old 07-04-2011, 10:03 PM
Dal_
Dal_'s Avatar
Might be worth a check.
Worth getting underneath and see if you can bang the exhaust onto the chassis or hanging pins anywhere. As the car corners (or drops from a kerb) the engine will flex on it's mounts and so move the exhaust.
Old 07-04-2011, 10:21 PM
botters
competant bodger
botters's Avatar
make sure the subframe bushes were fitted by someone with trhe correct fitting tool for them asthey will wreck them while fitting otherwise
Old 18-04-2011, 05:26 PM
mike St
mike St's Avatar
Checked the exhaust and no joy it is clear, and the bushes were changed by a competent garage so i am still at a loss to what is causing the noise ???
Old 18-04-2011, 05:32 PM
dojj
Resident Wrestling Legend
dojj's Avatar
the little rear arb drop links will be the cause if you've eliminated the exhaust and subframe bushes
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
03-11-2015 04:08 PM
andrewmctiernan
Wheels and Tyres
03-09-2015 08:22 PM
turbowag
03-09-2015 08:07 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: STDCi Mondeo Rear Knocking Noise
