2" coilover sleeves and 2.25" springs-universal
what you recon? Rally design do these mild steel coilover sleeves which you can weld onto your shocks, they also sell different length+ pound springs, £50 for front sleeves and £30 for springs going from 100lb to 600lb
So Eg. if your can has adjustable koni shocks but soft springs, you could take the springs off, knock/cut off the cup where the spring sits, and weld a sleeve over your shock, get a certain length+ lb spring -e.g 600lb same as Avo's +10 inch spring it should really be the same as genuine coilovers but alot cheaper, can cheange springs for cheap too
sleeves
http://www.rallydesign.co.uk/index.php?cPath=1358
Springs
http://www.rallydesign.co.uk/index.p...sort=2a&page=6
sleeves
Springs
