Any one ever had Vanos failure on a 328i?
My car has lost LOADS of performance at low RPM, (m52 1998 328i). But still pulls above 3-4000rpm normally.
Its an auto and just boggs at full throttle, it still kicks down alright etc. But my average mpg has gone from 20 to 17mpg too....
It all seems to point to vanos woes.... but its still smooth and silent.
Any thoughts on other causes?
Rob,
Rob,
Yea single vanos, not noisy at all. But apparently different parts can fail, one of them essentially locks the inlet in the retarded position so its got no low end power but goes like normal up the top (like mine) and the other failure makes the vanos area sound like its full of stones.
Just wondered if any one had ever had the same happen
I take it you've read the rebuild procedure on the Beisansytems site? You need to know what you're doing and have access to the Vanos tools IME
Hi mate,
A friend just came over and read the fault codes, the only code was as cam position sensor! So you may well be on the right track! But i have heard that the vanos failing doesn't always show a code, but it was operational (snap on scanner can make the vanos advance and retard at tick over).
Codes have been cleared, so i'll take it for a run and see whats what.
I have read a few rebuild procedures ect, and have looked at the BMW TIS disk. It certainly looks very doable, as long as i can get the viton seals etc, done far harder in the past.
Thanks for the replies, i'll let you know how it gets on.
Rob,
Rob,
Hi mate,
Rob,
Rob,
Easy to do
