cosworth iscv
cosworth iscv
I bought a new iscv off ebay as i was fed up with mine pratting around, fitted it and it starts fine but revs up to 2.5k and doesnt drop back
my old one starts fine but randomly revs its self
im planning on getting the car mapped properly, is the iscv needed ? can it be mapped to start without ?
can the old ones be stripped down and cleaned properly, ive tried the wd40 and oil before but its never worked
cheers paul
cheers paul
Dont strip an iscv by any means, small nut has a habit of fallin into intake and getting chewed up, remove it , drop it into an eggcup of petrol up to the flange and leave for 12 hrs .pulse the soluble a few times with a 9v battery (pp3) with some wire jumpers and remove and refit....
Will be perfect , it gets gummed up by emulstion(sp) in the fuel
Rock and roll
Rock and roll
Rock and roll
Rock and roll
i did think about the software but wanted to iron everything else out before it goes off for mapping got new loom aswell so not that, will try the petrol trick
i got a EBAY one and it did the same its the springs in side the ebay ones that are rong there to soft all so my one fell apart when i was driving but i was very looky as i have a swedish plenum so my one was upside down and never fell into the motor there shit
how is the TPS calibrated James? I think I'll have to do mine as I somethimes have the same problem. I've got a secs monitor and even on idle the monitor sometimes shows the throttle position to be 15%.
would calibrating the tps solve this?
To set the tps you have to check the voltage between pins 11'and 17 you want to see under 0.5 volts throttle closed 4.5volts throttle open on a 2wd tps or reverse the voltages for 4x4 tps
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
