Transit abs pump
Old Feb 17, 2011 | 04:03 PM
gobble's Avatar
gobble
Default Transit abs pump
I have a 2005 transit that has failed the mot on the abs pump.
What I would like to know has anyone had the same and fitted a second hand pump? If so did it work and how hard was it?
Thanks Matt
Old Feb 17, 2011 | 04:35 PM
James's Avatar
James
probably the easiest to do on the ford range in recent years, remove fusebox and its just there!
biggest prob is bleeding the brakes afterwards.
unsure on a second hand one, get yours reconditioned?
Whats it actually failed on? is it leaking?
Old Feb 17, 2011 | 05:05 PM
gobble's Avatar
gobble
Thinking about it I did refill the brake fluid a coupe of weeks ago. It was empty has not gone down since but I'm only doing 15 mile round trip to work the last couple of weeks.
The garage where it failed the mot said they would have to replace the belt and reprogram the pump?
I can see there is no belt(which makes me wonder if they looked very hard) but didn't know about the reprograming.
the fault code that came up was c1095.
where could I get it reconditioned?
Old Feb 17, 2011 | 05:15 PM
James's Avatar
James
i don't know i'm afraid, try a google search, i know i had a customer a few years back who had his recon'd somewhere for about £100 iirc.
Old Feb 17, 2011 | 05:45 PM
gobble's Avatar
gobble
Thats better than the 2k the garage wants to change it.
I cant find anywhere that recon them so a second hand one will do for the time being
Old Feb 17, 2011 | 06:55 PM
James's Avatar
James
fuck me is that a ford dealer?
I don't know an exact price but i'd say that over-priced in a big way, phone around some local ford dealers.
Old Feb 17, 2011 | 08:05 PM
gobble's Avatar
gobble
That was 1500+vat for the pump from ford then fitting and he said it had to be programed?
he also said 35 for a belt ?
I looked at it after I got home I must admit I have not really looked at it before there is no belt near it. Looks easy enough to change, bleeding it could be a pain.
Does it need to be programmed ?
Old Feb 17, 2011 | 08:11 PM
james kiely's Avatar
james kiely
i dont think theirs a belt ,regarding bleeding is it not just a mater of disconnecting the pump and bleed as normal .i have a 06 broke at the minute i will have a look tomorow and see what the story is with the pump
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
