General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Front set of brembo evo calipers, using mk1 focus rs discs on a 2wd saph, will these calipers fit behind a 17" wheel, ive had to use 5mm spacers on the front of my car to get the momo's to clear the standard 2wd calipers so does anyone know how much wider the brembos are ?
Cheers tabs, i know you need brackets to bolt them on which with these is just a flat piece of ally/steel with 2 wider holes for the calipers and 2 inner holes for the hub mounting points, i just wondered how much wider the calipers are from say outer disc face to edge of caliper ? also is there any difference in the evo caliper from say 6 7 8 9 evo's.
mine clear the ultralights without any probs at all
dont spose you could go and poke a tape measure through your wheel and measure off the disc face to the widest part of the caliper so i know if the wheel will clear the caliper
my callipers are off an evo 8
FRS disc face to outer edge of calliper is 55mm
outer edge of calliper to the inside of the wheel spokes at the closest point is 10mm
and calliper to inside dia of wheel is 10mm
i use frs brembos and discs it was a straight fit i just had to get the brackets for the calipers to fit which i think i got off here im running 17 comp mo's on a 2wd saph
