cosworth dampers
Old 03-02-2011, 12:01 PM
YOREVOL
YOREVOL
YOREVOL's Avatar
Default cosworth dampers
anyone know the difference between 2wd and 4wd cossie dampers?
Old 03-02-2011, 12:39 PM
Fezman1
Fezman1's Avatar
Dont know about damper rates, but the actual damper tube on 4wd is larger diameter -front dampers that is.
Old 03-02-2011, 05:51 PM
As said 4wd front id much larger diameter, bottom eye fitting of the rear dampers also around 1/2" wider on the 4wd, though can be cut down to fit 2wd, or 2wd one packed out with spacers(washers) to fit 4wd arms.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
28
08-09-2015 07:10 PM
Adam Graham
06-09-2015 06:04 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: cosworth dampers
