where can i get a worm and cog for my spit?
i had my blacksmith pal make me a spit,it works well but when the car gets near vertical it is trying to pull you off your feet.what i need is a cog and a worm to keep it under control when turning it over and to lock it at different angles,also so i can do it on my own.i have checked ebay but no success,any ideas?
I'd suggest a cog system like you find on a winch as it's designed to be pretty low geared and usually has some sort of locking system on it as well.probably get one off a boat quite cheaply or even and old towing dolly etc.
if i could get a worm and a wheel i could make plates to hold it and weld the wheel to the part which the spit rotates on,as it is its bloody dangerous as when it gets past a certain point theres no stopping it,i removed the engine and box today hoping that would help balance it but if it wasnt for a ratchet strap safety system then the car would have been upside down again.
See link:
http://www.hpcgears.com/products/worms_wheels.htm
You shouldn't need any gears tbh, you need to adjust the brackets that mount to the shell so the c of g is centered properly, once sorted you can spin the shell wherever you like with ease. Then you can drill a few holes in the spindles so the shell can be fixed at o', 45' 90' etc.
i thought about the center of gravity and adjusting the brackets,looks like thats what ill do to be safer as until youre hanging onto the end of a pole with no help you dont appreciate the force this thing has.
a worm and wheel would do the trick but there would be some stress on the gear,if it gave and you were next to it it would fxk your day up.
I can help.... :)
Hi,
if you send the broken part off to
Kayleigh Goodban
Ondrives Ltd
Foxwood Industrial Park
Foxwood Road
Chesterfield
Derbyshire
ENGLAND
S41 9RN
www.ondrives.com
it me, and i can make it for you. i work for a big company and do all the pricing.
i love everything cossie and will help you however i can.
hope this helps.....
my mail is kayleighgoodban@yahoo.co.uk
kayleigh
Is that a complete car? These things are designed for an emtpy shell - not a whole car. Your shell won't stand up to being suspended by it's extremities either. Don't do any welding as at the moment, the shell will be bowed (assuming it's not already been seam welded).
Turbocharging Technician
blakey100
04-08-2015 08:17 PM
