radiator
Hello mate you can try running sentinel x800 in the system for a week, then drain it all out and refill with a good inhibitor.
The best thing is to try and get someone to powerflush the system with FX2, this can be quite expensive but it should take 6-8 hours if done correctly but this will sort out any problems you have.
Pat
Pat
The best CAR rad flush I've used is wynns rad flush, I leave this in for 200 or so miles, all the gunge finds it's way to the expansion tank, which then needs cleaning out, but it works wonders on the rest of the system.
cossie fan (unluckerly)
si work on dafs and when a upec engine dose its oil cooler and put 20 odd liters of oil in the cooling system its a hell of a job to get it clean and turck wash and water works very well even it it dose take a good few miles! never seen it do any damage to hoses or alloy engine parts!
