General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
ISCV are same, the only difference on the tb(afaik) is the 2wd uses a slightly different idle speed screw, that is longer with a locknut, where the 4wd doesn't use a lock nut and has a shorter screw, as I say afaik.
Yes ST TB is different, not to do with the idle screw it's bigger IIRC, also some ISCV'S incorporate a diode (Which is indicated on the top) but esentially it's still the same.
