Zetec Help
just got the Mrs a 2.0 Focus, 2002. All seemed fine on the test drive, but on the way home the idle started buggering about. Grrrrr
After a bit of research it seems to be a fairly common problem, which I'm glad about! Looks like it messing about when getting warm, going from normal idle to just under 2000 rpm, to stalling at times.
I'm going to investigate further, and replace the ISCV and PCV if needed, but....
There's a curly pipe coming from the bulkhead to what I'm guessing is the fuel rail with push connectors, now I would have thought (rightly or wrongly) that this is the fuel in, but it seems to be a very loose fit and sounds like it's pissing air out..... Is this the fuel rail, and if so, is the noise fuel under pressure?
Didn't take a pic, and can't bloody find one! Hope someone can help.
Edit: Maybe i should've posted this in the technical help section? Mods, please feel free to move if needed. Sorry!
Last edited by northernmonkey; Jan 22, 2011 at 04:40 PM. Reason: Coz I'm stooopid.
Shudda bought the 1.6 like you were asking about earlier
i would first try cleaning the ISCV in carbon cleaner overnight.
I would also check the Vehicle speed sensor is working correctly (as you say it smetimes wants to stall)
Are you speedo clock lights also flickering on idle? if so I would also check all the eathing points in the engine bay for corrosion, just to make sure the idle issue isnt actually an electical problem due to simply a bad earth.
Hope this helps
Hope this helps
Ha Ha, yeah i know but the bodywork on the 1600 was shite! I've had this problem on my mondy duratec and it turned out to be a pipe under the inlet manifiold, as i said though, it didn't show itself till nearly home.
Speedo clocks not flickering, and speedo working all ok.
Cheers for the suggestions, there is a broken earth which goes to the engine lifting hook thing, but if i can still hear air pissing from the fuel (i think) inlet and also when it tuen off, i can hear hissing for a few seconds.
Poxy fords! lol
Poxy fords! lol
yeah, i can smell fuel, i'm almost sure it is a fuel line but the hissing is confusing.
I'll go out now, see if i can get one, it could be dark though! lol
Edit; here,
Edit; here,
if you can see petrol leaking from the pipe then dont drive it and get anew one from ford
cheers paul
Just to update anyone that's interested.
Took it round to mark_24v_wiring this morning who plugged it in (EML light come on during the journey over!) He looked at the fault code, then did a live read.
Turns out the upper and lower o2 sensors are all over the place and by the sounds of the exhaust etc and the readings, it looks like the cat has gone. Bugger!!!!
Not a cheap fix, but apparently it will sort out the bad running, shit tickover and when done, it should get back to normal power!
The fuel return is all good too. So thanks for the replies and help everyone.
it may help pay for your new one
cheers paul
Not that many yards around us, but i did hear the price had dropped again. Be interesting to find out!
Yep, as the tesco advert says, every little helps! I just hope this sorts it now, I've been in faster funeral cars!
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
