Guess the power, update and more graphs
Old 31-01-2011, 01:22 PM
  #241
coswurv
coswurv's Avatar
Originally Posted by BigErn
Danny.... M5 just sold and Im back to work now fella. Expect contact soon
Ian whats happened to your cossie, is it still the same one ?
Old 31-01-2011, 03:04 PM
  #242
Moonstone Steve.
Moonstone Steve.'s Avatar
Originally Posted by cossie4i
You found out whats up with your air injectors Steve ?
Steve
Spoke to Luke today, going down in the morning, he said the tps needs a slight tweek, also going to sort my cold start out as its rough as fook
Steve
Old 31-01-2011, 03:15 PM
  #243
James @ M Developments.
James @ M Developments.'s Avatar
shouldnt that be checked/adjusted BEFORE any mapping is done?
I check/adjust all sensors for operation and sweep using data logging equipment before we do any mapping, if the TPS calibration wasnt checked first how do you know it even reaches WOT?
you will have to leave the car for a few days to complete a good cold start map, as if you drive there and come back the same day. it will never be cold lol.Thats why we take them in for a week,
Old 31-01-2011, 03:18 PM
  #244
Staffi
Staffi's Avatar
Don't start another slanging match James/Stu
Old 31-01-2011, 03:23 PM
  #245
Moonstone Steve.
At least it should get to page ten faster lol
Steve
Old 31-01-2011, 03:25 PM
  #246
Not digging, just asking, maybe it was checked? would hope so.
Old 31-01-2011, 03:26 PM
  #247
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Just get Luke to use my cold start map, its perfect
Steve
Old 31-01-2011, 03:27 PM
  #248
If it was the case all cold start maps were the same im sure he could lol.
The ultimate test is usually day 4 for us, Cold start and drive, to simulate a stop start trip to work
Old 31-01-2011, 03:30 PM
  #249
Moonstone Steve.
Luke did say he checked it but may need a tweek, will find out what tomorrow brings.
Steve
Old 31-01-2011, 03:32 PM
  #250
Staffi
Staffi's Avatar
Steve, Moonstone one
Is it hunting then on cold start??
  #251
Moonstone Steve.
How do you get off the shelf chips good the m8, mine i bought from msd and ran till now was spot on, started first turn, idled nice and when warm ticked over at 900rpm.....lucky or pure skill?????????
Steve
Old 31-01-2011, 03:34 PM
  #252
Staffi
Staffi's Avatar
Steve, i was just going to ask that, how just fitting a chip can have good cold starts....
Old 31-01-2011, 03:35 PM
  #253
Moonstone Steve.
more a jump from 500>1500 rpm then 1500>500 again till it gets warmish.
Steve
  #254
We have done so many, we use the closest spec we have, sometimes we do need to make tweeks.
Old 31-01-2011, 03:37 PM
  #255
cossie4i+
TT T38 Power
cossie4i+'s Avatar
As EP can copy MSD chips get Luke to put your cold start map on from that chip
Steve
  #256
Moonstone Steve.
I have had two from msd at differant specs and if i/m honest the cold start has been the best part of them both.
Steve
Old 31-01-2011, 03:39 PM
  #257
Steve
Again not quite that easy, the cold start map is a global correction over the fuel map. So the cold start map from one chip may and most probably wont work or work the same on another if the fuel map has been changed.
You need the fuel map done first, then map the cold start correction.
Old 31-01-2011, 03:42 PM
  #258
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Im just a Train Driver.
I just follow rails and signals
Steve
  #259
Moonstone Steve.
Steve
Luke knows what he has to do m8 and no mention of msd chips was discussed
Steve
Old 31-01-2011, 03:44 PM
  #260
Moonstone Steve.
Im just a tight Train Driver.
Steve
Steve
Old 31-01-2011, 03:46 PM
  #261
im sure he will sort it,
But the ultimate and best way is to emulate the old girl, and actually do the cold start live when its cold.
Then leave it over night and check your work as cold start adjustment time is very short.
Old 31-01-2011, 03:50 PM
  #262
Staffi
Staffi's Avatar
So excuse my ignorance here James, cold start can only be done/altered/tweaked when it's a live mapped car correct??
Old 31-01-2011, 03:53 PM
  #263
you can tweek and adjust it when ever you want, but you can only get it perfect live, when you actually adjust it and tweek it during a warm up cycle.
our off the shelf chips are pretty damm good because we have done so many, and can get them pretty close, but there is always room for improvement.
some cars and specs can come off cold start faster than others, some need more enrichment that others, there are so many adjustments to make, it really is best done live IMO especially if its an odd spec, luckily they normally get done live anyway.
Old 31-01-2011, 03:56 PM
  #264
Staffi
Staffi's Avatar
Good to hear James as Mark's fitting one of yours to my car in a month or so...
I want flames too....
Old 31-01-2011, 03:59 PM
  #265
Moonstone Steve.
I'm sure they will sort it, by the look of the above posts they have a couple of jobs pending on it
Steve
  #266
we dont get many flames on over run as we use the fuel cut lol.
Mark is one of the tuners we trust and if the chip needs tweeks we can work with him to perfect it, but your sort of spec should be a walk in the park
Old 31-01-2011, 04:02 PM
  #267
Moonstone Steve.
James mine dosen't seem to need long on cold start, less than a minute i would say and it is fine.
Steve
Old 31-01-2011, 04:03 PM
  #268
Staffi
Staffi's Avatar
James,
My plan is, i'm going to use my 4x4 Inlet, Mark's cam which i'm pretty sure is going to be a ABO7, my T35.5 and i have 72lbs, so hopefully a chip can be written for this or one quite aggresive so to speak...
Old 31-01-2011, 04:05 PM
  #269
we would have to see what we have available for the 72s Pete, its not a common one for us to use really, most just go to 83s.
Old 31-01-2011, 04:12 PM
  #270
Miller 3
Miller 3's Avatar
I want flames too
Can fuel cut be turned off via a switch??? lol
Old 31-01-2011, 04:14 PM
  #271
Yes doug, turn the ALS on lol
Old 31-01-2011, 04:15 PM
  #272
Moonstone Steve.
With the price of Vmax you pair want to burn it outside the combustion chamber.......bonkers.
Steve
Old 31-01-2011, 04:17 PM
  #273
Staffi
Staffi's Avatar
I just thought flames were had from richness of the chip/map on over-run??
I'm lost now...
Steve, part of cossie ownership NEEDS to be flames mate..
Old 31-01-2011, 04:22 PM
  #274
you will get the odd flash and flame, but they wont bellow flames out like some
all cars produced with a cat will have a fuel cut on over run to protect the cat, so most cars on the road these days.including most cossies.
ive seen some dump so much fuel in on over run, you get borewash and also a load of smoke when you get back on the power lol. totally pointless imo.
im sure you have all heard the "its to cool the pistons bruv" comment lol, like pooring fuel in and setting fire to it will make it run cooler than no fuel, no fire, and fresh air will lol.
But thats another topic all together.
Old 31-01-2011, 04:23 PM
  #275
Moonstone Steve.
I'm lost now...
My old msd chip used to flame when the egt got in the higher temps
Steve
Old 31-01-2011, 04:35 PM
  #276
Miller 3
Miller 3's Avatar
Cool
Maxxxxxxxie
Old 31-01-2011, 04:53 PM
  #277
J1mbo
B1mbo
J1mbo's Avatar
Steve
I have a bit of over run in my map as I like the flames out the back when having a play nothing wrong with that
Old 31-01-2011, 04:57 PM
  #278
J1mbo
B1mbo
J1mbo's Avatar
that's not true, it just takes longer
Old 31-01-2011, 05:04 PM
  #279
Yes, so long infact most don't bother and just leave it near enough lol
Old 31-01-2011, 05:09 PM
  #280
J1mbo
B1mbo
J1mbo's Avatar
Maybe you should have put its a lot more difficult to get it perfect lol
Maybe people have different ideas on what perfect is? Like on full boost some map overly rich ?!
Quick Reply: Guess the power, update and more graphs
