General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
You can use water as lube(not advised realy if your new to it),you can also make a lube with a decent ph neutrol shampoo like ags,if you use a cheap one ive found it attacks the clay and makes it break up
I use the auto glym kit. You get the clay bar which comes in a tin,the lube micro fibre cloth and a big rowl off they net looking polishing cloth and a little bottle of super resin polish. When ive used the clay bar the last few times ive just used a squirty bottle to keep the panel im doing wet.
sounds like it mate seem to get good results theres a few vids on youtube aswell improves the paintwork loads! ill post my results up when i give it a go
I have used them all over the years and this is a fine compounded one with its own lubricant built in, so you only have to keep the paintwork wet. I always use this one on a wet car straight after washing. Wash off, dry, a good quality polish, and then a wax.
Its good stuff,cant knock it..its this this and the cyc one i keep reaching for
