Rant!! Aftermarket Cossy engine looms!
Why do I seem to get so many problems with them?
It's always a misfire at a certain rpm and I see it far too often, I have a car on the rollers right now with a brand new loom and everytime it hits 6.2k under load is misfires its tits off, replace it with my shonky old Ford slave loom and zero misfires just pure power.
The last two have been by the same person yes (the only persons looms that I've never had an issue with is Ian Spotter) , the previous one was a non existant crimp on no3 injector, don't have a clue what's up with this one. Trouble is you end up suspecting it's plugs, crank sensor, phase etc etc and by the time you've got down to diagnosing the issue you're into a lot of dyno time and why should the customer pick up the tab???????
Poor workmanship was the last one, don't know with the current one.
I know two people that have Ryan looms, and they are very well built (IMHO), and have been on the respective cars without fault for a couple of years now. Does Ryan still make looms?
Martin, I just CW Looms for my looms.
You can contact them at cw_looms@hotmail.co.uk please mention my name when doing
Here's a little example pic:
pointless post unless your going to name them as it isnt fair to all the loom makers as you are basicly putting doubt in peoples minds regarding ALL loom makers and thats not right
How would you feel is somone posted " one of the tuners of here was shit " blar blar blar , People could assume its you when it isnt ?
If you have been supplied with a bad loom, that you've sold to and fitted for a customer, that's different...
Yes he is still making looms but mainly for bike team now so isn't taking on much other work as far as I'm aware.
He has named them, it's anyone apart from Ian Spotter.
Rough idea on price for a 4wd?I could reloom it myself but if it's not stupid I may give this a go?I know my fuel pump needs doing and fan circuit but I'm pretty confident I can do all that on my own following the guides on here.
Sorry don't know the prices atm. Contact them through the provided email adress. Most likely you'll get a reply within a day.
Martin
As ive said before give me a bell on this one. If im not able to take on the work i can certainly point you in the right direction.
Cheers Mark
Cheers Mark
Depends.... Older looms suffer from contamination, work hardening of the wires as they move, corrosion, all leading to open circuits or high resistances. The looms can also suffer from a breakdown of insulation or sheilding allowing short circuits or elecromagnetic interferance to disrupt signals.
New looms can suffer from all of the above, plus incorrect crimping of terminations, wrong wiring spec etc.
I know Ryan and I'm sure if its a loom of his he would of offered to sort it.
Received 1,044 Likes
If he has had the problem before with one of Ryans looms I'm suprised he didn't just chuck another loom on it to rule that out, spending hours diagnosing something you are already aware has had problems for you in the past is a very arse about face way of doing things IMO
Saying that a loom swap isn't a 5 min job which I appreciate but still if that had of been me and I had a loom there I'd of tried it before looking into other things
No one is perfect and I think Ryan has done more than enough work to prove he is more than capable of doing his job well, sometimes things don't go right and maybe calling him would of been a more sensible choice than coming on here moaning about it which has clearly got a few people concerned about the quality of his work.
For reference I know someone who uses Ryans looms without issues, he has done a few for me which have always worked perfectly and no doubt many people on here will say the same.
