Brake Master Cylinder Help
I have removed the brake master cylinder from my 3dr as I believe it is causing the problem with my brakes, is there anywhere it can be sent to be reconditioned? Any info would be great, many thanks
I had a problem with one that was seized - no fluid out of rear brake lines and solid pedal. Just took it off and replaced it with a decent one off Ebay.
Actually I have a mint spare on the shelf if you need one and you're local (London). Postage cost loads last time I sent one somewhere.
Charlie
Charlie
