Garratt's new GTX range turbos
#82
Thought it sounded a lot when he quoted as i worked it out roughly it would cost £1450 from the states to your door inc 20% VAT - i did read on one of the websites that they come minus the compressor housing so i take it they add that on top at over £200 + VAT
#84
would you not get one over from the states your self? thats what ill be doing if i go for one you can buy one for £1150 to your door or £935 to your door with out the ex housing thats for the gtx3076. the ex housing off your gt3076 will fit it
#86
I'm not actually going to buy one as that amount of money is better spent elsewhere at the min - in fact i would rather buy a Spec R cooler
#87
I've bought expensive parts from the states before, coming from a reputable company out there i very much doubt they will cut corners on the insurance value or marking as trial parts etc - the import charges, VAT, admin costs etc will add up to £1400+ as i've already worked it out - they don't come with a compressor housing either as you have to use your own or buy a new one from a company over here which are £120
its £1150 with the housing and £935 with out your gt3076 housing will fit a gtx one . i have got tools from the states its about i had to pay 10% on top of what they cost
#88
The GTX range does not come with exhaust housing but they do come with comp housing,
I am just about to test a GTX3071 in a coupld of weeks.
Mark
#92
#93
I have only ever been in a cosworth with t3, t34, t38, t4 on and i like the way there is always a little bit lag and then bang the boost is in.
Is this what its like with gt turbos or are they smother and no bang feeling like someone just pushed you?
Would like to know as i am thinking of selling my t4 and not sure what i want next
Cheers Bram
Cheers Bram
#98
http://shop.ebay.co.uk/i.html?_nkw=G....c0.m270.l1313
You must be lucky as when parts come through customs in this country they get hammered with everything they can, i can assure you it isn't 10% in England as VAT alone is 20% and i had to pay nearly £400 on a set of wheels from the states
http://www.atpturbo.com/mm5/merchant...egory_Code=GTX
#110
I can see no reason at all for it to be any better or worse at ALS than a GT turbo is, as the compressor wheel isnt really an issue from an ALS point of view.
So you are talking very mild ALS only IMHO, if ALS is something you want in a big way then go for a maram shafted T4 or T34.
i find it makes no difference and im on autronic with it.... just spec the engine right and its not needed
i find all its good for is scaring people (which is funny tho) lol
#111
Cheers Bram
Cheers Bram
but will still spin the wheels in 3dr no problem as i found out lol
#114
*** Sierra RS Custard ***
Cheers Bram
Cheers Bram
Cheers,
Ade.
#116
Happily retired
#117
Mines on a GT35R, (well, was on one - the GT35R has just died, awaiting test results of the EFR and GTX35R so will be one or the other) it is laggy even on twin scroll set up but when it does hit boost it fells like an exocet missile has just hit you from behind
Cheers,
Ade.
Cheers,
Ade.
Ade,
Was gonna drop you a PM mate as I knew you went back to Mark's on Saturday, was the loss of power due to the turbo in the end?
#118
Yep, looks that way. I stripped everything down for Mark to check the cam timing and all was good. Put it all back together, Mark had started to adjust the cold running map when we started to hear a little squeal in the area of the turbo. Took the air filter hose off and found very slight marks on the compressor housing where the blades had began to touch. The noise just got progressively worse. By the time I crawled back to Bristol it sounded like a cats chorus, properly fucked It had driven fine on the way to Marks in the morning, gave it some serious stick as well.
Oh well.....
Cheers,
Ade.
#119
Cheers,
Ade.
Last edited by MAD Ade; 04-02-2011 at 06:35 PM. Reason: my poor spelling on the very rare occasion
#120
Its good to see the HUGE power Mark and others are making using these modern GT turbos but it does seem that they are just being pushed way too hard causing reliability issues.
Are they just generally weak or is it the massive boost pressure thats just finishing them off so quick ?
