Ford Focus ECU Key Chip Help
As some of you might no im bilding a FOCUS COSWORTH and iv just got hold of a new loom for the car its out of a auto but that wont bother me but as i might be going to try and run the FOCUS dash clocks i need to get the FOCUS ECU to work them i will be running a cosworth ECU to run the motor . but the thing is iv not got the chip for the FOCUS ECU i have asked the tat yard were i got it from but the key went with one of the doors . Is there any way to trick the FOCUS ECU into thinking the chip is there . If any one dose no if it can be done i would not exspect you to post the info on here but could you PM me it would be a very big help to me....Thanks for your time on this matter
No mate the cosworth ECU dose not run any clock,s i may just have to run my escort clock,s
there is a place nere me that can plug into the ECU and make a new chip but the last time i had this done it cost me Ł88
yer pats is an arse Iv got an st engine to go in my car luckly I got the chips from the breakers ,I have heard that pats can be disabled with the right kit , but not to sure about that though , best of fortune dude thats one hell of a project !!!
just an after thought the sensor signals will be coming from the cos parts like tacho signal from the EDIS unit and vss on the cos box ? so even if the focus ecu was running would thare not be signal conflict ?
