RS2000 ECU codes
Old Dec 20, 2010 | 12:54 PM
V8monster's Avatar
V8monster
Grease Monkey
Default RS2000 ECU codes
does anyone know if you can fit ECU's with a different 4-letter code on the tag? mine got shorted out (by me) so i bought one off some twat on the rs2000-16v forum who said he had the right one for me, but its turned up and the code is AFAR (mine was FALL, i did tell him this), and it says 4wd on it, mine is 2wd! iv plugged it in anyway and the car is still dead on the key, if you power up fuel pump and ignition relays manually the starter turns but the injectors dont fire (grounds arent pulsing)
Old Dec 20, 2010 | 01:09 PM
spud-rs2k123's Avatar
spud-rs2k123
Don't think you can mate I'm sure it as to be the same code.
Old Dec 20, 2010 | 05:00 PM
Icurus's Avatar
Icurus
You really need the same code to be sure of it working.
Is that for a mk6? if so, they have PATS do they not? In which case you would need the ECU's matching key and transponder?
Old Dec 21, 2010 | 12:55 PM
V8monster's Avatar
V8monster
Grease Monkey
its a mk5 mate the PATS is in a seperate control unit so im fairly sure the ECU doesnt read the key...
And i really dont know whats up with it not even sure if the ecu is the problem or not now. all i know is it doesnt power up the efi and fuel pump relays by itself (although the ignition relay switches like it should), and if i cheat and put power to the efi relay it does power up the fuel pump relay, but STILL the pump doesnt run.... so if i NOW take a feed straight to the pump loom the pump runs, the engine turns over and sparks, but the bloody injectors dont fire. the two switched earths to the injectors seem to go live at the ECU when the ignition is on, and not ground out at all to fire the injectors, but im a bit lost with it now to be honest
Old Dec 21, 2010 | 01:34 PM
JamesR1's Avatar
JamesR1
Anybody for a brew?
Could the new ECU be a duff?
Old Dec 21, 2010 | 02:08 PM
ScORTED's Avatar
ScORTED
Project Money Pit
you have a mk6 ecu with internal pats and your trying to fit it to a mk5 with either external or no pats... do you have chipped keys and whats your cars build date?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
