sparkys quick question
Old Dec 3, 2010 | 03:14 PM
cozzy jeff's Avatar
cozzy jeff
Default sparkys quick question
my sister wants a light put in her loft,can i take a spur off the landing light fitting,not bothered if it comes on with the landing light,any more advice would be great.
Old Dec 3, 2010 | 03:32 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Just do that mate simples
Old Dec 3, 2010 | 03:33 PM
RSricRS's Avatar
RSricRS
But do remember to knock the power off at the db board lol
Old Dec 3, 2010 | 03:34 PM
vaughant's Avatar
vaughant
Tis fine,you'll often find a spur up there if it's had an aerial booster fitted in the past,you can use that for a feed if you prefer?
Old Dec 3, 2010 | 05:18 PM
fish99's Avatar
fish99
If the landing light has a live feed to the fitting connect another cable to that. You can then either feed a switch or feed the loft light fitting then add a switch to that.
Old Dec 3, 2010 | 05:59 PM
3drzetec's Avatar
3drzetec
arnt the wires for the lights running in the loft? there should be a joint box up there some where, join in that??
Old Dec 3, 2010 | 06:01 PM
danneth's Avatar
danneth
TORQUE!
No one can give the correct answer without knowing how the house is wired, or what is in the loft
Old Dec 3, 2010 | 06:07 PM
St3V3_C's Avatar
St3V3_C
Yes, but not really right if it only works with the landing light - show us a pic of the ceiling rose for the landing light and we can go from there.
Old Dec 3, 2010 | 06:09 PM
adduk's Avatar
adduk
IF the lights are wired in a loop in setup then all you need to do is come off the loop at a ceiling rose on the upstairs and bring a neutal with it to a switch, just switch the live then up to the fitting. But this is altering the circuit so therefore requires testing to prove the circuit and cable. So only right way to do it is to get a spark in. This way you know its safe and installed correctly.
adam
Old Dec 3, 2010 | 06:13 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
adam
well done that man (regards last statement)
Old Dec 3, 2010 | 06:23 PM
cozzy jeff's Avatar
cozzy jeff
adam
i here what your saying,this light is only going to be used occasionaly,when putting stuff in the loft ect,thats why i thought running off the landing light will be the easiest way to do it,i can get a pic of the rose at the weekend if its going to help any.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
