engine coolant frozen ? HELP
mums gone out to her car started fine...drove for about 5-10 mins an the temp has hit the red...my guess is the waters all frozen inside the engine cos can see little icy bits on the tank...any ideas how to defrost it all ? so can get some anti freeze in there asap...the car was bought from a guy who worked in a garage couple months back so didnt check to see if all ready had some in there
thanks
thanks
Anybody for a brew?
the heat of the running engine i would have thought would have thawed it. If its been frozen around the water pump prop there is a good chance it might have damaged the water pump when the engine started.
yh thats what i ment didnt wanna put it in straight away jus get all the frozen water out but the best way quickest cos shes a mobile carer so needs car...would it not be ok to tip warm water in there or isit that a bad idea?
I had the same problem with my old Series 2 many moons ago. It had anti freeze in it ( brown stuff ) but it still froze. The car ran hot but and no hot air was coming out of the heater vents. When I stopped the heater matrix behind the dash board split spilling a large amount of water all over the interior... lovelly.
Good luck with it, hopefuly you wont have the same problem I had.
Regarding no heaters,I had this on the Corsa this weekend,locate the two pipes going into the matrix and pour boiling water over the pipes,double check you've got flow through the rad,mine was frozen both ends!!!
My car came back to temp fine,I refilled the system with coolant but no heaters,I took it for a short drive with the temp just over 90 and all of a sudden the cabin was full of heat.I think you've just airlocked it.try moving the heater controls from warm to cold and back a few times to check the valves working ok.
Then,check for leaks,mine seems to heve developed one by the waterpump and it's dripping when running now,not badly but it's noticeable so another job to do!!!
