Turbo timer Question
Old Jan 28, 2005 | 05:00 PM
S1 Barkham's Avatar
S1 Barkham
Default Turbo timer Question
I have bought a GReddy Turbo Timer and have just fitted it. There was only three wires that go onto the ignition barrel... i fitted them and it all comes on, even reads the Voltage from the battery correctly.
Only problem is when i turn the ignition off the engine doesn't stay on, it switches off! Any ideas what could be up??
ThaNKS
Old Jan 28, 2005 | 05:02 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Is there a wire that goes to the Handbrake?
Old Jan 28, 2005 | 05:03 PM
mattbibs's Avatar
mattbibs
is it earthed correctly?
Old Jan 28, 2005 | 05:04 PM
S1 Barkham's Avatar
S1 Barkham
Yeah but it went too dark and i didn't have time to wire it.
Old Jan 28, 2005 | 05:07 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
bingo
Old Jan 28, 2005 | 05:08 PM
Christian and Beccy
#1 in Spelling Club
LOL. The Turbo Timer needs to see that the Handbrake is on. Get the wire connected and it will work.
Old Jan 28, 2005 | 05:09 PM
S1 Barkham's Avatar
S1 Barkham
Thanks peeps will go sort it!
Old Jan 28, 2005 | 05:49 PM
bud-weis's Avatar
bud-weis
Football Cwazy
dunno if it is supposed to but mine turns off if i only turn the key back one notch, i have to do it quickly back to off position otherwise it just cuts out
Old Jan 28, 2005 | 06:24 PM
cressy's Avatar
cressy
so wot ur sayin is that the turbo timer not work if it`s not wired up 2 hand brake?i av a simalir problem with my blitz thort it worked a how hard the turbo ad been workin if any nows if this is the case on a blitz dual turbo timer it would B a BIG help cheers
Old Jan 28, 2005 | 06:26 PM
Ish's Avatar
Ish
all brands of turbo timer i have seen so far have a wire that needs to be wired to the handbrake.
it is a safety feature where if you leave you car running on the timer and some one gains access to the car and attempts to drive off in it when they put the handbrake down the car will cut out!
some people just connect the handbrake wire to earth if they don't want to use this feature
Old Jan 28, 2005 | 06:38 PM
S1 Barkham's Avatar
S1 Barkham
It also has a Speed sensor wire to turn it on when your moving....... any ideas where this would go on a series 1 thanks
Old Jan 28, 2005 | 06:55 PM
S1 Barkham's Avatar
S1 Barkham
anyone?
Old Jan 28, 2005 | 06:57 PM
mattbibs's Avatar
mattbibs
i have the blitz one. it has a built in boost gauge to work out how hard you ave been driving. so it needs plumping into a vacuum hose if you want to use this feature.
Old Jan 28, 2005 | 07:36 PM
S1 Barkham's Avatar
S1 Barkham
bump
Old Jan 29, 2005 | 12:04 AM
S1 Barkham's Avatar
S1 Barkham
anyone?
Matt Baxter
Sep 16, 2015 08:30 PM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
