Can you run a race technology dash or aim dash from a pectel t2 ecu?
Old 16-11-2010, 06:23 AM
M K
M K's Avatar
Default Can you run a race technology dash or aim dash from a pectel t2 ecu?
Thinking of ecu's for the fiesta cossie and there are a few pectel t2 ecu's that have come up for sale for good money at £350 each so as a t6 is 4 times the money and a bit overkill for a cossie track toy I'm considering the t2,
Just want to know if you can read direct from one with a race technology dash2 or aim dash etc,
Thanks
Marc
Old 16-11-2010, 07:38 AM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Thanks
Marc
My MG runs T2 and an AIM dash and it works great, T6 is better though as you can input more stuff into the ecu (oil pres, fuel pres etc) which you can then have displayed on the dash but with T2 you simply have to wire up the sensors and input them into the dash directly.
Old 16-11-2010, 08:14 AM
M K
M K's Avatar
That's the info I was after Martin, thanks
Would you say it's a good option for the Price then Martin as £350 for the ecu on open developer compared to t6 is very cheap and
To be honest I think if I was to step up I'd go for life racing f88 over t6 as it's a new ecu that's in currently still being produced and is approx £1200 new so still better value than t6 I think.
Old 16-11-2010, 08:17 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
T2 has no data stream output, so as Martin says, the AIM would have to be standalone .
Martin-Hadland
Rubbish Mike!!
Old 16-11-2010, 08:23 AM
Mike Rainbird
Caraholic
Originally Posted by Martin-Reyland
Rubbish Mike!!
Seriously? I know it can't talk to a Pectel monitor, so I thought that if it couldn't do that, it couldn't data stream to a dash. I stand corrected then and learn something new each day .
How many outputs can it display to the dash?
Old 16-11-2010, 09:08 AM
andrewg
andrewg's Avatar
i fitted T2 and racetechnoligy dash 22 to that green esc
Old 16-11-2010, 09:15 AM
Mike Rainbird
Caraholic
What does it display from the ECU?
Old 16-11-2010, 09:21 AM
focus 4x4
focus 4x4's Avatar
Good thread this !
Old 16-11-2010, 09:25 AM
R5FORD
R5FORD's Avatar
T2 works with sec monitors aswel
Old 16-11-2010, 09:29 AM
andrewg
andrewg's Avatar
same as it sees from standard sensors, coolant , air temp , throttle angle, boost, rpm . and put in analogue oil press and fuel press.
and also picked up the pulse from the sensor at the speedo drive for speed
Old 16-11-2010, 09:41 AM
DaveEscos
DaveEscos's Avatar
Mike... piss poor product knowledge!
This is YOUR market, you should know things like this, like the back of your limp wristed hand!
I'd have no clients if I acted like this at work!
Old 16-11-2010, 10:25 AM
M K
M K's Avatar
Looks like a good option then,
Is £350 a good price for a new open t2 ecu?
Old 16-11-2010, 11:04 AM
Martin-Hadland
Yes as long as its not a wierdly spec'd one, I'd be interested in one at that price.
Old 16-11-2010, 11:14 AM
Mike Rainbird
Caraholic
As you can see, I don't normally deal with T2s . T6 is my favourite .
Old 16-11-2010, 11:16 AM
Mike Rainbird
Caraholic
Aaah, so does that mean the dashes are being piggy backed off the hairbrush connections on a T2 like the SECS monitors then (rather than data streaming from CAN etc like T6 does)?
Old 16-11-2010, 11:21 AM
DaveEscos
DaveEscos's Avatar
Why deal with the paupers, eh Mike!
Old 16-11-2010, 11:43 AM
M K
M K's Avatar
Martin,
I just had a chat with tommy at FMS about them and he said the same, they may need another speed input added if there fo N/A to map the boost and a couple of other board mods which will soon bump the price up,
It's Chris Birkbeck who has the ecu's so may be worth giving him a shout, he wants £350 each or £325 if buying 2
Thanks
Marc
Old 16-11-2010, 12:08 PM
Gav Diamond
Gav Diamond's Avatar
Yes Mike
It is only 3 wires to wire in
http://www.aimsports.com/pdf/ECU-AIM_Logger_110_eng.pdf
Scroll down to page 52
Old 16-11-2010, 12:14 PM
Mike Rainbird
Caraholic
Cool that is really good to know .
Old 16-11-2010, 12:15 PM
Mike Rainbird
Caraholic
T6 just does EVERYTHING (and then some ).
Old 16-11-2010, 12:18 PM
rs-tuner
rs-tuner's Avatar
Well it's not called scumbag motorsport is it!
Old 16-11-2010, 12:31 PM
andrewg
andrewg's Avatar
L8 etc can talk to a monitor but not dash 2 etc which confused me!
Old 16-11-2010, 01:04 PM
Martin-Hadland
No it doesn't mean that at all Mike! Have this...
Old 16-11-2010, 01:09 PM
Mike Rainbird
Caraholic
You're too slow - see post 19 .
Old 16-11-2010, 01:12 PM
Martin-Hadland
I don't need to.... I know how it works. Eat that banana!
Old 16-11-2010, 01:13 PM
JonnyBravo
JonnyBravo's Avatar
Does the T2 require a external trigger wheel ?
For a example if used on a Vauxhall ?
Mike Rainbird
Caraholic
I prefer peanuts !
Old 16-11-2010, 01:14 PM
Martin-Hadland
It works with 36-1 so if the original is different then a trigger ring would need fitting.
Here's how I did it on my MG..
Crank pulley, original and machined...
Cam trigger half way through being fitted (T2 uses one lug)....
Old 16-11-2010, 01:15 PM
JonnyBravo
JonnyBravo's Avatar
Thanks Martin, that answers my question perfectly.
Old 16-11-2010, 09:49 PM
Franco
Franco's Avatar
BJD........
Even I'm in the 'T6 and AIM dash' gang
Old 16-11-2010, 10:04 PM
Franco
Franco's Avatar
Old 17-11-2010, 09:34 AM
Mike Rainbird
Caraholic
Originally Posted by Franco
BJD........
You're the exception that proves the rule !
Old 17-11-2010, 11:50 AM
LINCOLN
LINCOLN's Avatar
As said above set the pectel to "stack" output serial comms.... cannot map with the dash connected so may change a few things (eg/ fan control) you do when mapping.
Old 17-11-2010, 11:55 AM
Mike Rainbird
Caraholic
How are you getting on with the mapping of yours?
Old 17-11-2010, 12:04 PM
LINCOLN
LINCOLN's Avatar
Next week mike - i am away at the mo.
Will let you know mate. When you coming for holiday?
Old 17-11-2010, 12:13 PM
Mike Rainbird
Caraholic
I will defo take you up on this at some time, but need daughter to be a little older to cope with the length of the flight (she's a very hyper 7 going on 12 ) .
Old 17-11-2010, 12:19 PM
rs-tuner
rs-tuner's Avatar
Is this on a 20v t Martin?
Old 17-11-2010, 04:19 PM
Martin-Hadland
Yes, here's a couple of better pics of the cam trigger install using a Cosworth YB cam trigger with EECIV crank sensor and bracket. Had to drill and tap one M6 threaded hole otherwise straight fit.
Old 17-11-2010, 04:22 PM
rs-tuner
rs-tuner's Avatar
Can the t2 not run the individual coils?
Quick Reply: Can you run a race technology dash or aim dash from a pectel t2 ecu?
