air intake pipe on a capri ques
founder of chicken porn
i keep having to re attach the air pipe on top of the airbox when starting it it goes bang n wont start till i re do the juberlee clip up
is there any reason it should keep doing it apart from it being worn n needing replaicing
Some sort of backfire is pressurising the intake system and blowing the weakest link, ie air pipe on top of airbox, off to relase the pressure.
I would be checking your ignition timing firstly.
The engine will not run with the pipe off because it it needed to raise the plate on the metering head and therefore allow fuel to flow to the injectors. (in very basic terms)
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
