40 year old head just wont budge!
Hi guys, i need some suggestions please!
I was asked to crack the head nuts/studs on an MF 165 tractor last night - it belongs to the other halfs old man and he expected them to be tight after 40 years.
Anyway, all 23 (yes odd, but the book verified this, and the full removal procedure) nuts came off without too mush fuss considering it's thought they had not been touched since new, but the head itself wouldn't budge!
It's a cast iron head so we didn't go easy on it but its stuck firm, and no amount of tickling it with a lump of 4"x2" and a hammer or attempts to lever it off got us anywhere.
Short of driving in a flat-head between the block and head (not even considering that!), or putting the engine crane on the head loops, what options are left??
I've removed plenty of heads in the past, but never met one this stubborn!!
Tom
PS: I know i should of taken a photo, but the oil was thicker than porridge and had made a right old mess!
Tom
*** Sierra RS Custard ***
Turning over isnt a bad suggestion IMHO, not like its going to start with no manifolds etc on anyway, so wont do any harm (assuming its a cam in block engine which it must be at that age?)
Head probably weights so much that it could seem like its not wanting to budge when you try and move it even if there isnt much resistance.
Lifting eyes on the head were a good suggestion too, and once the strain is taken so that the bottom end is a cm off the ground (ie its taking all the weight on the head lifting eyes but doesnt have far to fall) then beat the bottom end with a sledge hammer to see if the vibrations will help shift it.
The whole things is to be stripped and rebuilt anyway, so worst comes to the worse we will take the sump off, drop the internals and 'tap' the head off from up through the liners!
Tom
I'm pretty sure its stuck though - although the fulcrum wasn't perfectly 'placed' when we tried levering it off, it was having none of it, and the 1" dia 4' long steel bar i was hanging on was bending...
Crane it is i think.
Tom
Unfortunately turning it over isn't an option otherwise that would have made for a fun alternative.
Tom
Tom
You mean that the pistons can come out the bottom of the bores?
Thats handy then!
Ive not seen any engines like that other than the old F1 monoblocks.
Patronus
i'd go with brute force and ignorance, followed by more brute force and a bit more ignorance. I presume you've filled the bores with oil already and left it for a while to see if it works it way in and helps ?
Not entirely sure how you'd get the pistons out and tap the head up from underneath either as pretty much all cylinder bores are tapered so the pistons can only go out the top.
He/we haven't (didn't plan to remove the head ot be honest - just crack it), but its a good suggestion.
Cheers guys
Tom
I thought the moment i started the thread i was going to regret not taking some, but i doubt he will touch it without me so there is still time.
Re the rings chip - i've no idea either. It did sound odd, but the story he told included an argument with his brother about the pistons, so it *should* of stuck in his mind.
Tom
Tom
cossie fan (unluckerly)
sounds like your in trouble lol ive seen old studed laylands like this and the only way to get the head off is to try and lift it a bit with wedges then cut the studs but leaveing enough to be able to get the stud out! i see a guy trying to pull the heads off a bus with straps and a fork lift and would just lift the bus lol have u tryed pouring hot oil all round it then leaveing it to soak while under tension with some wedges baged in iver side!
Many years ago i had a Massy Ferguson 178, we could not get the head off for a engine rebuild so me and the fitter removed the sump and i am sure the pistons came out the bottom and he shoved bit of 2x2 up number one bore and one up number four and jacked the head of with two trolly jacks, one under each bit off wood.
This was over twenty years ago but i am sure it worked.
We were warned by a older guy in the workshop to watch our eyes if we cranked it over as diesel squirting out between the head and block could blined you
Ive just asked my stepdad about this as he used to work on tractors like this all the way through his apprenticship.
He said its the studs that are holding on to it and to try putting it under tension and pour diesel around all the studs and leave it to soak in over night with the weight of the tractor on it that way the diesel should find its way down and free the studs up.
If that doesnt work he said to try and wind the studs out of the block.
Yea that what we done, jacked up the trollly jack to take the weight of the tractor, i think in the morning it done the job, as i said it was a long time ago
gchristophi
31-08-2015 10:36 PM
ekjim
17-08-2015 08:57 PM
