escort van owners
on my 55d there's a knocking from the rear end. I've taken a look, and it appears as if the rear leaf springs are slapping together when the suspension rises making a curious knocking sound, Any suggestions?
a decent look so would be interesting if someone has had and solved this problem
On the shorter spring there should be a clamp at either end that holds the 2 together but over time they come off. Not sure if you can buy the new clamps on there own but worth giving ford a call
My knocking noises turn out to be the leaf spring bushes worn to shit if that helps,& whilst i was there i had to nip the u bolts up on the leaf spring to axle..
just a thought if you still have the spare wheel & carrier under neath check that aswell
its defo the sprigs at the edge of the small bottom one its tapping on the upper large one
my old one did that it turned out that the rear shock mount had rotted away so when i jacked the van up the shock fell out i drove it around for near on six months like this
...just for the record, mine wasn't that bad
