stack fuel level guage - fixed!
Old Oct 28, 2010 | 10:01 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default stack fuel level guage - fixed!
I've got a stack fuel level guage in the 3dr, but can't get it to read above empty!
its the stepper motor one, but not the pro series.
I have tried the custom callibration where you start with an empty tank and fill it.
tank is pro alloy with a VDO sender but pro have ground off the numbers on it. iirc alex said it was a 90 ohm sender, but if I set the guage to that, or anything else it still doesn't work.
any ideas people?
cheers
Old Oct 28, 2010 | 10:03 PM
Danny @ Enhanced Performance's Avatar
How you doing dan????hows the car coming on now???
cheers danny
Old Oct 28, 2010 | 10:14 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
not bad cheers danny. not really had chance to anything yet as I've been working away again.
trying to source a 2wd rear end at th mo, but I am toally broke now.
need to sell a 4x4 rear diff and I should have most of the funds for the 2wd stuff.
then I think the vibration luke was saying about is the prop bearing as there is a lot of play in it.
then sort the fuelling side, mot an tax and bring it back to you lol
but gonna be months at this rate
Old Oct 28, 2010 | 10:19 PM
Miller 3's Avatar
Miller 3
any ideas people?
cheers
Put some fuel in it you tight cunt
Old Oct 28, 2010 | 10:23 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
did you not read the bit about the custom setup, where you fill it up?
specsavers for you, sonny!
Old Oct 28, 2010 | 10:32 PM
Miller 3's Avatar
Miller 3
No i did read it, but i know what your like' you probably filled it up with fresh air to save a few quid lol
Old Oct 29, 2010 | 08:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no, i did brim it, it was at that point that i found that the tank leaks for the seal where all the gubbins goes...
why does nothing, 'just work' ?
Old Oct 30, 2010 | 07:49 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I realise it dont help you but mine worked first time are you sure you have followed the instructions 100%. I did mine with the unit out of the tank & moved the float by hand if that helps.
Old Oct 30, 2010 | 08:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers rod, well there is only the purple wire that you connect to the sender, then a +ve and -ve, lumination, and the 2 wires for the switch.
so im pretty sure its connected right lol. i will take it out and double check tho!
i suppose it is possible that the float is stuck down, as it was ages before any fuel went in the tank. dont really want to take it out, but if i have to i will.
Old Nov 7, 2010 | 11:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
been out pissing about with it tonight...
getting 5.39V to the sender, is that right? thought it should be 12v lol
anyway, i took the sender out the tank, and upon doing the custom callibration by just turngin it upside down to indicate full, it was still reading empty...
so got the float to move halfway, and low and behold the guage went up a bit...
so empty is actually full, and full is empty and yes, it does have a full tank of BP's finest!
tried checking all the wiring etc and couldnt see anything amis... but now the guage doesnt light up when you turn the lights on.
id had enough by that point so came in...
any ideas on the inverted reading thing? is it just a case of swapping the pos and neg wires around? or wont that work?
Old Nov 8, 2010 | 12:17 AM
jon@work's Avatar
jon@work
turn the tank upside down ?
Old Nov 8, 2010 | 06:57 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Get some tippex and modify the "F" to an "E" and then with black marker modify the "E" to "F" - Hope that helps
Old Nov 8, 2010 | 07:05 AM
Spiky's Avatar
Spiky
dare i say wired up the wrong way around
Old Nov 8, 2010 | 07:24 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
So when the car is on its roof the gauge works fine? I'd leave it as it is then
Old Nov 8, 2010 | 11:20 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Yup just turn the gauge upside down. Et voila!
Old Nov 8, 2010 | 02:22 PM
R4N SS's Avatar
R4N SS
thats what i was thinking
Old Nov 8, 2010 | 03:47 PM
martysmartie's Avatar
martysmartie
It sounds as if the polarity has been reversed!
Martin
Old Nov 8, 2010 | 07:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the wiring harness has the +12ve and -ve in te same places as the other guages, so you have a 12v feed, 2x neg?wires that it says doesn't matter which one is conneced to earth, the white illumination wire, a purple sender wire, then a brown that is used with one of the neg wires to change the settings.
so I realy don't think its wired up wrong!
Old Nov 9, 2010 | 09:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
does anyone else have a valid input?
Old Nov 9, 2010 | 10:02 PM
creator's Avatar
creator
Possible Faulty gauge?
Old Nov 9, 2010 | 10:08 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
possibly, I bought them all off rainbird, and he's a bit of a dodgy beggar :cry;
Old Nov 9, 2010 | 10:44 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
You could rig up a series of small mirrors to invert the reading.
Old Nov 12, 2010 | 08:43 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
so can anyone answer me if the 5.39v im getting accross the sender is right?
will have another look tomoz and see if i can do anything else with it, before it gets tossed in the bin...
Old Nov 12, 2010 | 09:00 PM
Spiky's Avatar
Spiky
Afaik, the send should be based on a negative and not positive volts
Old Nov 12, 2010 | 09:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
could well be then, as it was showing a minus lol
Old Nov 13, 2010 | 08:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
right, had another look today.
took the sender out again, and took the tube off to see if the float was a magnet, a bit like some senders we use at work, where you can just turn the float round and it will read properly.
anyway, its not like that, there are 2 thin wires that the float passes over with a wiper. so put it back how it was.
tried the custom callibration again, and low and behold, it fooking worked!
what joy, so i put the dash back together and re ran the sender wire throught the conduit...
turned it on again and the cunt was just sat on empty!
so i disconnected the st700sr, boost gauge and the fog light switch as these were all disconnected when it did work, and the fuker was just sat on empty still.
CUNT!
if i put the sender wire to earth, the guage reads full, so what the fuck is going on?!?
also i found that the main seal that seals the black plate on the fuel tank is fucked, hence why the god damn tank leaks! so need a new one of those too!
Old Nov 13, 2010 | 10:05 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Throw the gauge away & use a stick with knotches on to tell you how much petrol you have .
Seriously I had probs to start with so took the sender out of the tank & hey presto it calibrated, mind you it worked when i put it all back together as well .
Old Nov 13, 2010 | 10:13 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
According to Stack.
If no Sensor is connected, the pointer will move to the empty position indicating an error.
Also check the sensor with a ohm meter & check its within the calibration range that the Stack can cope with.
Old Nov 13, 2010 | 10:19 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers rod, ill see if i can measure it tomoz if i can be arsed to take it out again!
thing that got me was that it DID seem to work, and then didnt
Old Nov 13, 2010 | 10:40 PM
jon@work's Avatar
jon@work
is the sender earthed ? (which it needs to be)
Old Nov 13, 2010 | 10:47 PM
Gav Diamond's Avatar
Gav Diamond
Does anyone know if there is instuctions for the fuel level gauge on the net.
I have looked on the Stack web site but when i press the download button on the fuel level one it gives instuctions for boost gauge, i have tried for every gauge and non are for fuel level.
Thanks
Old Nov 13, 2010 | 11:11 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yes, checked that
gav:
http://www.stackltd.com/pdf/manuals_...50-1445-00.pdf
Old Nov 14, 2010 | 01:30 AM
Gav Diamond
Thanks for that mate.
I have the normal version though not the pro control gauge with the buttons.
Will have to email them.
Old Nov 14, 2010 | 01:36 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
what do you need to know mate as i have the instructions for mine handy.
mine sint the pro either, but the basic setup is the same.
red wire is +12v
there are 2 balc wires, doesnt matter which one is connected to earth
purple is the sender wire
white is illumination
the brown and spare black are for setup.
to do a custom setup, hold the brown and black wires together, turn on power, it will then go into setup mode, wait for the pointer to get to 7/8 and release the wires
turn power off, then back on. set empty point by quickly touching the wires, then the guage will sweep tot he full mark.
fill the tank, or turn the sender upside down if its out the tank, but remember to earth it lol. then quickly touch the wire again. it should now be set and read the correct level.
Old Nov 14, 2010 | 01:42 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
What was wrong with the original fuel guage?
Old Nov 14, 2010 | 02:27 PM
Gav Diamond
red wire is +12v
Thanks for that mate,
Basically i bought the gauge second hand and never got instuctions but need it to work on the standard Sierra level sender
Old Nov 14, 2010 | 04:45 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
do you know what ohm the std sender is?
as if you look at the link, you can set it pre set values. just power up with the wires touching and select the correct one, then power off. job done lol
Old Nov 14, 2010 | 05:16 PM
Dlatch!'s Avatar
Dlatch!
got a pic of the sender
reverse reading could also be which way the float is set on the bottom of the sender and will change which way the arm will change resistance
so if you have the space in the tank try having the float arm coming out the opposite side it is now which will swap which way it will work.
but as stated only wiring will be sensor wire to insulated tab on sender (check no short between this and sender body) and then just make sure sender body is earthed. if sender body is not earthed properly grounding out the sensor wire won't do anything
Old Nov 14, 2010 | 05:23 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the sender is in a tube, so the float just goes up and down a bit like this
ill triple check the sensor is earthed and that the tab isnt in a bit.
Old Nov 14, 2010 | 05:29 PM
Dlatch!'s Avatar
Dlatch!
ahh yh thats a complete different sensor but still check the earthing.
ideally run a separate earth wire straight to sensor to car body, you won't get a good earth through a alloy tank.
edit to add have you had a multimeter on the sensor to check resistance does actually change when float rises?
