Combi Boiler in loft......
We have always had an issue with high gas consumption and I am now wondering if the fact that our Combi Boiler in the loft may be at least part of the reason? The Boiler is on the gable end of our bungalow and not enclosed, just in the open loft space. Do you think the fact that the Boiler is in a cold environment could be contributing to how much it costs to run? I reckon I'm going to box it into an insulated 'cupboard', but wondered what plumbers/heating engineers think about my idea?
as above lag the pipes as far as possible. But the location of the boiler itself shouldn't make any difference at all..the flue pipe has two parts (a pipe inside another) one pipe lets the exhaust fumes out and the other is draws the air into the burner for the combustion (room sealed). All the heat exchanger/burner are all enclosed so won't effect these. all you can really do is lag as much of the heating, cold main and hot water pipes as far as possible. also check to where your boiler thermostat is set to.. this can make a huge difference on cost. most people think upto the maximum, but just over half way is plenty. I take it you have a room stat fitted ? also turn it down a few degrees and saves more money. hope this helps.
Resident Wrestling Legend
"normally" the spot where you have your cold water heated up tends to be as close as possible to where you want your hot water to come out, which is why they are normally in the kitchen and the kitchen is above/below/next to the bath
if you are running the pipes from one end to the other then lagging certainly would help, but moving it might be the best in the long run
The original Rouge Trader
Your talking bollocks again Dojj.
so do you normally put your boilers anywhere but the kitchen then?
no one, and i mean no one i've ever seen or visited or even houses i've viewed to buy in all my days has had their boiler anywhere but the kitchen, so that's why i've gone with the "normally"
i mean, where else would you put it?
so unless he's got a gas leak?
or it's too far away and it's kicking in because the water's getting cooler sooner in the radiators?
i have fitted numerous boilers in lofts,in bedroom cupboards,garages etc.you have to fit them either where the owner wants it,where the conditions allow you,the flue can be a pain in the arse due to gas regulations.
if its miles away from the furthest hot tap it will waste gas heating water which wont be used but it wouldnt be that much water in a 3 bed normal house.
i used to work for transco and the amount of times we got called out to check for a leak and read a meter as folk had got a big bill,not 1 time did i find a leak.sometimes when you were doing other work you would find a leak the tenant didnt know about,or did and didnt report it.
Tiff, yes, its been properly commissioned and serviced (almost) annually. I recently had a Vaillant specialist out to take a look at it and he was happy that it was running correctly. I know I have other matters to look at, we are in the process of going large on the loft insulation. We have 100mm at best, but a few places have nothing. Most of the pipes are lagged. I just want to know we've done all we can. We chose to have it in the loft, so don't really want to move it. There is some waiting involved in getting hot water to the taps, but I reckon its the heating thats doing it. Well, that and Rosies lengthy hot showers, she seems to be the only one unwilling to make any compromises to lower our energy bills. I have discussed our high gas bills many times on here, but never the matter of the boiler being 'cold'.
Considering what the boiler is (Vaillant Turbomax 837e), it is MORE than capable of what we want from it, but I still have to have the heating temp on the boiler set high for the rooms to stand a chance of getting warm enough. Our room stat is set to 21°. I guess we'll see what its like when we sort the insulation, which we are doing during November. There is alot of sorting out to do in our loft before we can properly insulate and we are gradually getting rid of the GU10 downlighters, so want to do that and finish all the electrical bits-and-pieces before rolling another 170mm of insulation over the whole lot.
my boilers in the kitchen in both houses, ones up on the wall and has a cabinet built around it, and one is up on the wall and has a full lengths cabinet around it and i'm not saying they weren't ALL in the kitchens previously, ours was in one of the chimney breasts so when we had it out we put it into the kitchen as it was the closest place for the gas and had a wall to put the flue out of, same with everyone else, but now they are ALL in the kitchen built into a unit of a cabinet some place why would you want to run miles of pipework when you can have it all done in the shortest length possible? there must be a max run of about 10 feet to the hot water taps in the kitchen and not more than 20 feet to the furthest tap in the bath
post whore
i know loads of people with theres upstairs and quite a few people with it in there garage thats bolted on to the house.shouldnt matter if its at one end of the house or the other.
Although my boiler is in the loft, it is directly above the kitchen, which is adjacent to the bathroom. I can honestly say that the water has to go much less distance to my bathroom from the boiler in the loft than where it originally was before we moved it.
I'm pinning my hopes on insulation, for Rosie's sake. If that doesn't fix it, I'll be dealing with her hot showers by shutting the hot valve right down.
on the other hand, what price plan are you on?
As its a Valliant have you got the warm start feature turned on (it will have a C in the display if you have) ? as this keeps the boiler at a nice 65 temp ready for when you open a hot tap great if you are in all day not so great if you are out all day plus your boiler is in a nice cold roof space which means its gets cooler quicker and then has to warm its self up more using more gas and the best thing is your not evern at home needed it
cheers
dunc
also see how many units of gas you have used (read your meter also will say on your bill) as gas has gone up quite a bit but see what you are using and report back
cheers
dunc
cheers
dunc
cheers
dunc
Your theory about the cold boiler needing to warm up in its cold environment is pretty much my concern and why I think I'm going to box it in. Kinda like a car taking twice as long to warm up in winter than it does in the summer.
Mines in the loft and works great,granted it takes a touch longer to get to the kitchen sink and the utility but it's seconds really,perfectly liveable.
If you think about it guys,dojj could never put the boiler in the garage.............the heat coming from it may have damaged the bentley paintwork!!!!
still got it btw, and he's still paying me Ł100 a week to park it there so say what you want about it
sounds like you need to get your insulation sorted and go from there as its no good heating your house up and then lossing it out the roof and walls but the warm start is a great feature and saves water plus you dont have to wait for the boiler to kick in and worth trying as you may find it suits you better
just turn the hot water to max and the letter C will apear then you can turn the hot water down to what you want and as long as you dont turn it to min the warm start will stay on, if you want to turn it off then turn the water to min and the C will go and then turn the water back up to what you want and as long as you dont turn it to max it wont switch back on but you can easy tell just make sure the C is not on
How long do you run it for every day?
As in, does it come on in the morning and off at night?
I know its obvious, but if the house in empty in the day, have it coming on 1/2 hour before you get up and run it for an hour while you get ready for work etc.
Or, turn it down a few degress and put an extra jumper on. Sounds silly, but it will save you a fortune.
I get calls all the time for stuff like high bills etc and its amazing how many people run the heating all day.
Do you have a spare room? Is the rad off in it? Got the heat reflective film behind the rads? Also double glazing?
All the little things add up to a good saving at the end of each month!
a good money saver... when you run a bath in your house do you use the cold tap? if you do all your doing is throwing your money away. you pay to heat your hot water up and fill the bath, then just put the cold tap on to cool it down...?? so adjust your water temp on your boiler. once its set to your perfect temp you should run a bath with only your hot tap to be most efficient
