5 link setups!? & diff!?
Old Jan 26, 2005 | 10:02 AM
B19-TRB's Avatar
B19-TRB
Default 5 link setups!? & diff!?
1 for the old skoolers i supose
But if the rear of a car is all prepped for 5 link setup what bits would i need to buy!? as i have no idea what a 5 linksetup is!
also what sort of diff cn i use with it!? & how much for somethin that can handle a cossie engine runnin 400hp!?
Old Jan 26, 2005 | 12:06 PM
Matt's Avatar
Matt
means jack to me lol i think claws is 6 linked......
Old Jan 26, 2005 | 12:24 PM
B19-TRB's Avatar
B19-TRB
was hopin dingo would reply!
as as usual i aint got a fudgin clue!
Old Jan 26, 2005 | 12:27 PM
Phil's Avatar
Phil
Jeebus
4 links are the bars infront of the axle, then the 5th link can be a Panhard rod or Watts linkage (as above sometimes called a 6 link kit cos it does link to the chassis at 6 places).
If it is prepped for 5 link then you will need an atlas axle with the mountings, a ZF diff, uprated half shafts etc. You will also need the link bars and bushes and the actual panhard rod itself which runs across the back of the axle.
Rally And Competition Equipment (RACE) in Stoke will be able to sort you out, but a decent axle aint cheap at all. Brand new their options range from 3.5k upto over 5k! And most of the diff options are of a short ratio rally variety.
Old Jan 26, 2005 | 12:39 PM
B19-TRB's Avatar
B19-TRB
Cheers Phil!
Old Jan 26, 2005 | 12:47 PM
foreigneRS's Avatar
foreigneRS
Testing the future
check out rally design online. they have some stuff that shows what the 5 'links' are iirc.
on a std solid rear axled ford like mk1/2 'scort, the axle is connected to the shell by the leaf springs. these 'control' the sideways movement of the axle, the fore and aft movement, and of course the up and down movement. not very well though.
the first step to improving the axle location is to add 2 forward facing links. these were fitted to the rs2000 as standard and are often called anti-tramp bars as it is said that they help to stop the leaf spring winding up which makes the axle tramp. personally i think that's bollox and axle tramping occurs when you don't have enough damping for the stength of spring that you have.
you can then add the turrets to the shell to have coil over spring and damper units, which gives you a wider choice of spring rates and ride height adjustment. you can then eliminate the leaf springs altogether, but then you need something to stop the axle moving sideways. a panhard rod connects one side of the axle to one side of the shell, a watts linkage is pictured above and connects to both sides of the shell. then you also need another 2 links to stop the axle wanting to rotate (these with the previos 2 'anti-tramp bars' are your 4 links).
Old Jan 26, 2005 | 05:20 PM
Diff ratios start at 3.09 to 5.5 for an atlas
3..44, 3.54, 3.7, 3.9, 4.1 etc etc etc
Old Jan 27, 2005 | 07:25 AM
B19-TRB's Avatar
B19-TRB
cheers boys!
it was a option i was lookin @ but goin on those prices of diffs from phil i think its a option i wont take!
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
