Cossie 24v conversion
As title i wan2 know bout 24v conversion.. i own sierra estate 1989 Freg in mint condition only 1.8cvh an no power so 24v cossie conversion calling.. Anyone done this conversion? whats needed an what work involved? any info would really be appreciated??? also will saffy interior fit? including door cards?
Regards Rob
Regards Rob
you need to convert the auto engine to be manual,xr4x4 flywheel and clutch,and a spigot bearing,a gearbox,a type 9 with an early 2.8 xr bellhousing or a hybrid mt box,front half 2.9 xr4x4,rear 2wd,it will go straight onto your mounts,rad piping is the same,wiring can be a bit of a pussy,you will need an injection tank and pump and fuel lines,you need to weld up the egr take off on the o/s manifold and use the egr inlet pipe for a vacuum for the servo.also,uprate the brakes to cope with the extra bhp and weight.
the saph cos front seats and doorcards will fit no problem,the rear seats are totally different and i think the doorcards may be a different shape.you prob could get the seats in with some home made brackets.
you need to convert the auto engine to be manual,xr4x4 flywheel and clutch,and a spigot bearing,a gearbox,a type 9 with an early 2.8 xr bellhousing or a hybrid mt box,front half 2.9 xr4x4,rear 2wd,it will go straight onto your maounts,rad piping is the same,wiring can be a bit of a pussy,you will need an injection tank and pump and fuel lines,you need to weld up the egr take off on the o/s manifold and use the egr inlet pipe for a vacuum for the servo.also,uprate the brakes to cope with the extra bhp and weight.
mark_wiring on here can do the wiring by post, steve also known as cossie4i i believe can put you in touch as they are brothers.
i wont give you the techy detail, but i'd reccomend you do it!
there are a few more steps involved as yours is a non-v6 to start with but none of it is a big drama
i've never used an injection tank, and yes if your giving it beans on some corners and the fuel is low it will cut out from time to time due to not getting fuel, but never found it to much of an issue, you could always use an external swirl pot,
mounts you just uses sierra v6 mounts
Resident Wrestling Legend
the 4wd mounts are different to the 2wd mounts, so if you fit them they won't fit or will be too long/short for what you want
remember to do the front suspension as the V6 is a bit of a porker in comparison
as for clutch/flywheel/starter options, there are loads, just use what matches the box you are fitting
there are 8 tooth and 9 tooth starters as well as 2 bolt and 3 bolt
wiring is a doddle
wiring is a doddle
when i wired mine it was a pre pats system dojj so didnt have the immobiliser.when i wired it up as top boss recommended it would wind all day but when the key was released it started.it was a wire that turns from neg to pos after you stop winding.got an auto electrician to wire it up in the end.as for the tank,why convert it then not fit a £80 fuel tank?
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
