Noise from front during cornering and braking....*PROBLEM SOLVED*
Chasing Radders
OK, got a noise coming from the front of the car during cornering and braking.... It sounds very similar to wheel bearings, but is not this is i have had 2 new bearings on the front today, took it for a drive and its still the same.
When cornering slowly you can hear like a slight whine....very similar to when your brake pads are low....
The same when stopping/appling the brake its the same noise....
In a straight line its fine when driving normal......
It seems to do it under cornering load and brake load....
I have just replaced the discs and pads about 6 weeks ago
New front wheel bearings today...
Still the same........Any ideas
Chasing Radders
HHHHHHHHHHmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
My Tyres are VERY VERY hard tbh......And i think they are filled with "Nitrogen" or something like that, thats what they said when i got them anyway.....
Maybe worth letting them down and filling them back up???
Chasing Radders
No spare wheels........... trying to think if it did it when i had ST rims on it......hhhmmmm
Tyres are Kuhmo's i think
Would it not do it all the time, ie in a straight line aswell.....
Chasing Radders
Chasing Radders
Marky boy...
1st off - yeh tyres... I've had similar on other car - serious.
2nd..... my mondeo did this but ford refused to change the wheel bearing - can you remember what it did when it eventually failed. Took out the whole right hand bottom arm/disc/pad/abs/driveshaft/hub. Ł1700 plus labour and vodka.
The ONLY time it would make the noise was under load when cornering at about 40mph+.
Are the bearings in straight in the hub?
I had this noise on my mondeo and had a new wheelbearing, it was still the same after. I only found out as the brake discs kept gradually warping, i took a guess the hub wasnt square, skimmed the warp out of the brake disks and all was ok, just lived with the odd noise every now and again
Chasing Radders
Right....just been out testing things...ie when it does it ect..
It makes the noise alot when breaking from 10mph to stop......you can really hear it, which points to the brakes, but i have new discs and pads about 2 months..
And also....why would it make the noise when going left and right...i even went to an empty car park and weaved the car as if going through some cones and it did it alot, while under load in gear and also just rolling........
Surley if it was tyres it would do it in a straight line.....it is the usual road noise...
Could it be a caliper issue.... while weaving could the calipers be sticking ect???
Tiff if the tyres need changing (possibly) move the back to the front just to see, wont cost you much, if anything.
Also, if were on about the mondy, check out the stabilizers, make sure they havent worn, cheap to replace though if they have.
I had the exact same problem on my ST mate and have put it down to my tyres!! I also have kumho ecstas on the front. Swapped front to back (had a a pair of avons on the rear) and the noise was gone! Certainly doesnt pay to buy cheap tyres!
Chasing Radders
OK..its looking likke tyres for sure somehow then.......
Need to try another set of wheels before i splash out
Received 1,044 Likes
Sometimes tyres get feathered on the edges which cause a similar noise to wheel bearings. It sounds like a wurring noise also can be heard when slowing down. I would swap the wheels with another set just to eliminate the wheels.
Chasing Radders
Just had the tracking done and it seems to of made it a slight quieter....popped into the local tyre place and he said the same, could be tyres..
Just need to borrow a pair of mondeo wheels now......
Thanks for al the input guys
