Cosworth racing pistons cvh rst....
Hi ive bought a set of cosworth racing pistons from burton power for my cvh rst there oversized by +1.5mm but do they need tops machining to get right compression.if so how much need taking off???
i will ring burton in morning but have not had time just thought i would see if anyone else would no...
cheers
jon
cheers
jon
just finding my feet
all cosworth racing pistons need the tops machining they only come unfinished
speak to em in burtons and they will sort ya out , theres a guy there who owns a fiat uno turbo, hes a good bloke, speak to him ( can remember his name and i speak to him alot at work
Originally Posted by Matt
1.5mm overbore on a high power cvh??????????????????? good luck. forget the pistons what about your block pal
oh and the pistons aint gonna be a problem
rods might be though
think ya will find there a .5 over bore
rods might be though [/quote]
Says in burton cataloge there +1.5mm oversized better be as i need a min of +1mm as block need rebore
They are 1.5mm. I know. And i know U wont have a problem with the block. From what u've said, u seem to be going into this engine build a little blind folded. Burton will not tell u how much to take off the top. What compression ratio have u specced the engine to? If u want 225 bhp, why bother with forged pistons and the increased problems they bring?
just want it back on road
Cosworth pistons are the best. But, the std rods need changing before u change to cosworth pistons, as std pistons will do over 250hp. Forged pistons are noisey when cold, and wear the block quicker. If all u want is 225 hp, then a std engine with stage 3 head and stage 2 turbo will do it no problem. Ask the engine builder what compression ratio u want (i'd advise 8:1) and then u can work out what to do with the pistons. Also, i need to have ur head CC'd.
ekjim
17-08-2015 08:57 PM
