Cosworth cooling on track
Having problems getting engine temps down. We are here now with 2. Both 4x4s. One with 240bhp no issues and one with 430 is getting hot. Got headlights and gril out. Any other options?
Thanks
Thanks
Air tec ally rad oil cooler fitted. Hot on track. Come in let it run and it cools down. When it's hot, cool air comes out blowers. When it cools hot comes out
cossie fan (unluckerly)
best mod i made to mine to keep the temps down was a turbo pre rad but i also have a 50mm core ally rad and mapped water injection for when the charge temp gets hot
The tubes on core on the Airtec rad are too big they are not cooling enough.
If you look at a std rad core and compare to an intercooler core they are different for a reason.
Then look at the Airtec products and they all use the SAME core.
my 350 saff, never got hot on track and that was using a std OE rad,
your rad might be blocked or you got an air lock
try a known good rad and see
on the 4x4 check the thermostat
If its got cold air when the cars hot and vice versa its got leakage issues!!!!
Check head gasket or heater matrix..
Never had probs with the airtec rads..
cheers danny
cheers danny
lukeeboy149
22-08-2015 04:29 PM
