damm my impact wrench is fooked, anyone got any ideas
Just bought a wheel nutt remover and need my impact wrench i goes to start it and all that happens is air coming out by the trigger, and nuttin turns etc, so took the fooker to bits, made sure all was ok, oiled etc but it still does the same, is there summit simple i need to do or is it fooked? it worked fine when it was put away and hasnet been dropped or anything really so a bit confused as to why its fooked, personally i think my car is delibertly nicking my wheel nut and fooking my wrench to purposly fook me off, i reackon the RST also nicked my multigym instructions as well
Originally Posted by Toe Knee
without takin the piss is there enuff air pressure gettting to it for it to be able to work?!?! Bit odd if it worked b4 with no probs
just took my compressor pipes etc off and retightened them, checked the tyre enflator and the sand blasting gun, plus the air gun and spraying gun all have lots of damm cold air and seem to have pressure behind them, may try to inflate a tyre or summit to check as if theres no pressure it shouldnt be able to inflate anything,
