throttle positon sensor.
im running around in a 1.8 zetec escort at the moment and it seems to misfire round about 4k its worse when under load ie going up a hill, been told its more than likely the tps is there anyway to check it or is it just replace and see? also do i nee to set it up or is it a one off one on affair? also when you lift off the throttle to change gears the revs hang for a few seconds could this be the same fault or would that be iscv??
Any help would be great.
mk3ste
17-10-2021 10:09 AM
mike elsome
14-09-2015 04:08 PM
