I-Tunes/HArd drive help....
Chasing Radders
I usually had my hard drive in the (F drive.....with all my itunes tracks saved on it.
But i have unplugged it and put it back in but now it is showing in the (G drive, so now my itunes cant see it....
How do i change where Itunes looks for tracks from (F to (G
you need to go up to 'add new folder to library' in the file menu.
then select the folder storing the music on the G drive and this will then sync with your library, then go into 'show duplicates' mode (cant remember where this is located) and remove the library references to the old folders located on F.
....or
you could just map the Hard drive to f: assuming its not taken....then all file references would still be valid.
....or
Did Someone Mention TUV
Tiffany,
to save explaining it look here mate:
http://support.microsoft.com/kb/307844
Im assuming you use Win XP?
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
