focus lights problem
Old Aug 21, 2010 | 01:33 PM
fezzajsy's Avatar
fezzajsy
Default focus lights problem
Why do the headlights come on when you depress the brake pedal?mrs just recently changed the brake light bulbs.any clues pliz?
Old Aug 21, 2010 | 01:38 PM
GUZZLER's Avatar
GUZZLER
wrong brake light bulbs?
Old Aug 21, 2010 | 01:42 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Silly girl got the bulbs wrong or fitten them wrong
Never let a woman do a mans work
Old Aug 21, 2010 | 01:49 PM
fezzajsy's Avatar
fezzajsy
fezzajsy's Avatar
fezzajsy
cheeRS lads
Old Aug 21, 2010 | 01:50 PM
Zanderford's Avatar
Zanderford
they're twin pole on them dont go to halfrauds tho local motorfactors best bet
Old Aug 21, 2010 | 01:53 PM
I bet the bulbs are in the wrong way round.
Old Aug 21, 2010 | 02:04 PM
Zanderford's Avatar
Zanderford
dont think you can put em in the wrong way round without forcing em the pins on the side arent symetrical
Old Aug 21, 2010 | 02:34 PM
fezzajsy's Avatar
fezzajsy
just swapped them n still headlights go on when u brake??
Old Aug 21, 2010 | 06:23 PM
B19 JUB's Avatar
B19 JUB
youve prob got a single filament bulb in there instead of correct twin filament.as u press brake pedal as its a single bulb its back feeding through sidelight circuit.
Old Aug 21, 2010 | 06:24 PM
Oranoco's Avatar
Oranoco
What he said
Old Aug 21, 2010 | 06:34 PM
fezzajsy's Avatar
fezzajsy
will have a looksy...cheers
Old Aug 21, 2010 | 06:36 PM
fezzajsy's Avatar
fezzajsy
if i remove them bulbs n leave em out shud stop the headlights coming on then?
Old Aug 21, 2010 | 06:37 PM
Oranoco's Avatar
Oranoco
Yup
Old Aug 21, 2010 | 09:44 PM
I would try that. Ive had c few vans at work where the drivers have put bulbs in the rear and when the press the brake the side lights have come on cause they have had single filiment bulbs in as mentioned above.
Old Aug 21, 2010 | 10:12 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
As mentioned, if it happened immediately after changing the bulb then check the bulb is correct. Also be worth checking the earth point in the boot as i've had weird problems such as all the indicators coming on dimly under braking when my earth had come loose
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
