saff coilovers
They can be made to fit by making a sleeve(tube) to take up the space between the thinner 2wd ones and the thicker 4wd ones needed in 4wd hubs.
The rear lower eye bolt on the rear dampers is a different width, wider on 4wd by about 1/2" but again can easily be overcome by using spacers to use 2wd ones on 4wd or cutting 4wd eye down 1/4" off each end, though I would imagine makers may have thought about this and supplied all 2wd with some spacers to suit 4wd, only need top produce one part that way.
