sierra cosworth 4x4 missfire
car runs perfect for 20 -25 km and after that it start to missfire. I cant understand why it start to missfire , every time it runs perfect at the begining but after some drive it missfire or cut out on 4000 rpm
leads, plugs coil etc,
or could be cts leaning it out when its warm etc
few differant ideas but start with the easiest 1st,
is it just missing when under load or at idle as well?
3dr Cosworth owner
mine does this between 3500 and 4500 rppm when fully warm, only under 100% throttle. fine at 75% throttle. ive put new ford plugs gapped correctly new motorsport leads and new dizzy cap and rotor arm from matt lewis. also runs on three for about 5 seconds when first started in a morning, i took plugs out the other day and number 3 was almost looking rusty and what looked like a bit of water on top of piston, ive resigned myslef to the fact the head gasket is on the way out as my mates escos has just been doing exacly the same and his was the head gasket. Dont matter though as its a excuse for a wrc head hasket and arp stud and nut kit, then......... More boost and a damn good set up. who shall i take it to though, im thinking harvey gibbs as he's not far from me at all
before doing all these.the cheapest check is to pull apart the wiring blocks that are clipped on to the baulkhead above the back of the engine(where they get very hot and can corrode) i had misfire problems and it was down to these.pulled them apart and cleaned them,put them back together and never had the issue again. after that try the other cheap options
If it is that shiyte Marelli cts,don't bother replacing it with another shiyte Marelli one.
Do like me and fit the sensor fitted to '92 Vw corrado/passats,exact same thread and very similuer values.
I've change 3 on my cosworth managed car and ever since using the Vw Bosch sensor i've had no problems since(i've got both sensors fitted onto the cyl.head side by side).
Cutting out,missfiring when under load(very dangerous when trying to overtake),pissing black smoke out of exhaust etc,etc..
Anutternutter
21-08-2015 06:07 PM
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
