General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
A boost hose to fit the GT30 turbo, its the pipe that comes from the cooler to the compressor housing, as the original silicone hose i have is to small ?
intercooler end i think is 70mm then it scales down to a smaller size to slide over the turbo, i need it to stay the same size to fit over the pipe on my GT30
That pipe should be the same size as a t34 one when I fitted my 30 I only needed to buy the air filter monster pipe, the one I had on the car from the cooler to the turbo compresser housing fitted
I have a 63mm one, fits my T38 and radtec intercooler
Measure the pipe on the intercooler and turbo lol
Steve
As said earlier its the same size as the intercooler end which off hand i thought was 70mm, if you try the pipe on back to front (standard ford red pipe), so intercooler end on the turbo it fits, hence why i said i need a pipe that goes from cooler to compressor housing and stays the same size, who sells them ?
So Charlie is the t34 pipe in question bigger than the 2wd saph cossie one as standard mate ?
I'm 99.9% sure it is mate but I do know that the compresser housing to intercooler pipe on mine fitted and I had a t34 turbo before I fitted my 30, I only had to buy the big monster air filter pipe from Roose
Luciano
Originally Posted by Niall.b
I got an rs500 one from roose with the tails left slightly longer & it fits perfectly
Right guy's ive measured the turbo and its 63mm in size so same as the intercooler, where can i get a hose to fit or is it just a case of ringing roose and having one specially made?
