how do i replace this ball joint
Old Jul 31, 2010 | 05:26 PM
rsturbo27's Avatar
rsturbo27
Angry how do i replace this ball joint
is it a all in 1 fixed wishbone arm item as the nuts are ovel so no way of getting the old ball joint off as i,v bought new ball joint do i have 2 buy a whole new wishbone with ball joint attached wot is the best way to get old ball joint off if there is a way thanks Name:  carstuff111010.jpg
Size:  102.7 KB Name:  carstuff111012-2.jpg
Old Jul 31, 2010 | 05:28 PM
rsturbo27's Avatar
rsturbo27
forgot 2 say car is a fiesta rst i know they should be only the 2 nut type but 4 sum reason its the 3 nut ball joint on this wishbone ?
Old Jul 31, 2010 | 05:34 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
you need to grind the old mushroom head/blind bolts off the arm,and then replace them and balljoint with the bolts provided with your new balljoint
if your lucky the holes will be the same size
Old Jul 31, 2010 | 05:40 PM
rsturbo27's Avatar
rsturbo27
cheers bud looks like i,ll have 2 do that
Old Jul 31, 2010 | 05:50 PM
vaughant's Avatar
vaughant
You tight cunt,there only about Ł15 for the complete arm in a motor factors,bought one for an escort on Friday,three bolts,15 minutes,job done!!
andy130's Avatar
andy130
as said cut the heads off the hammer them out, if they dont move then they need to be pressed out
Old Jul 31, 2010 | 05:53 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
Buy the arm you tight cunt lol
Old Jul 31, 2010 | 06:04 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
before you get the angle grinder out,
please change from those nike air jarusalems,and wear some proper protective footware
Old Jul 31, 2010 | 06:05 PM
rsturbo27's Avatar
rsturbo27
for fuk sake these ball joints cost me 9 fu@king quid each there going back now u told me that lol for 15quid i dont need the stress right kids it's safe to cum out again lol
Old Jul 31, 2010 | 06:08 PM
rsturbo27's Avatar
rsturbo27
there not nike's m8 there buzz lightyear size 6 space ranger dap's so fuk u lol
Old Jul 31, 2010 | 06:10 PM
Lloyd's Avatar
Lloyd
well you should have spent the extra on those as well,saved you even more grief.
Old Jul 31, 2010 | 06:16 PM
andy130's Avatar
andy130
are you buy frst arms for 15? as frst amrs ARE diff the normal fiesta's
vaughant's Avatar
vaughant
Sorry for calling you a tight cunt but I've fallen into this trap before by not realising just how cheap the full arm is,I'll check the invoice but I'm certain it was 11 or 12&vat!!two 15mm bolts/18mm spanner on top on the inner subframe,the ball joint and job done.
Old Jul 31, 2010 | 06:17 PM
rsturbo27's Avatar
rsturbo27
trust me m8 if i had never bought the boy the buzz one's i would of had grief allright
Old Jul 31, 2010 | 06:21 PM
vaughant's Avatar
vaughant
I'd be pretty certain their not,the hubs on all later fiestas are the same as turbos,I know cos I used to make them,subframes the same so where's the difference?Pretty sure the frst used a 1.1 box as well?
Old Jul 31, 2010 | 06:46 PM
chaffe's Avatar
chaffe
Turbocharging Technician
dont know why but feesty ones are much dearer than escort arms, nearer 50 quid each
Old Jul 31, 2010 | 06:50 PM
gary fraser's Avatar
gary fraser
genuine ford arms for the frst are 70 quid each, i put motor factor 1s on my frst and they lasted a couple of months, total shite if you ask me better with the ford 1s
Old Jul 31, 2010 | 07:03 PM
andy130's Avatar
andy130
the ball joint sits back about 10mm or so on frst ones, an yes ford ones last longer, worth 70 all day long.
Old Jul 31, 2010 | 07:30 PM
Alvyn's Avatar
Alvyn
as said above Frst one ARE different and cost more than standard Fiestas and any good motor factor should point that out to you, and also use Genuine Frauds ones if your keeping the car as they do last longer for some reason!
Old Jul 31, 2010 | 07:34 PM
rsturbo27's Avatar
rsturbo27
do ford still stock these ? if not who does
Old Jul 31, 2010 | 07:49 PM
gary fraser
they should do i got a set not long ago, the part numbers are 1054984 and 1054985 not sure which is passenger or drivers side though.
Old Jul 31, 2010 | 08:02 PM
andy130's Avatar
andy130
put two anyway
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
