Bleeding brakes on mk4 xr3i
I attempted to bleed my brakes after geting a new master cylinder. I know your supposed to start at the furthest away brake from master cylinder so went for the rear offside first. Fine got the nipple loose and got it bled. Went for the near side rear next and couldn't loosen the nipple, so I'm wondering if it really matters which brake order you do it in? And what happens if you do it in the wrong order. Thanks.
it dose help to do it in order but you will need to sort that nipple out i pefear to use a bleed kit that puts presser in the brake system this is wot iv got
http://cgi.ebay.co.uk/ONE-MAN-Brake-...item53e1ee746b
I've got the gunsons eezi bleed in the link but also have a vacuum bleeder for any awkward little bleeders!!
I've always started at the nearest saves my feet walking too much that way, and never had a problem on any car tbh.
Yeah I got a one man kit aswell. Just a cheap one. Cost a fiver. Just going to have to leave that brake out and leave for anuther day. Not even vice grips took it off. Will put on some penetrationg oil see if it will come loose. It's well rounded now lol
