Cosworth Polybushes
Chasing Radders
http://www.rallydesign.co.uk/catalog...oducts_id=5103
Much better than PolyFlex and more than half the price
Im looking to buy some poly bushes and i was going to buy powerflex ones, these ones at rallydesign do seem very cheap if not to cheap???
im just worried about the old saying you only get what you pay for!!!!
has anyone got these fitted from rallydesign and how do they rate against the powerflex ones???
Chasing Radders
I think it is more a case of Powerflex charging more for the name IMHO(Just like Samco)
You will not be dissapointed with the Rally Design/Polysport ones
Ryan , son listen to your dad
alot of peeps think having metal to metal on the car makes it's a horbile drive , that is a misconception ......ever since i have gone metal to metal you wouldn't belive how tight the car feels to drive on the rd or track ...the supension is just right for both jobs I E : it's not too hard for either ..........it took me 3 to 4 times to get the car right the way i wanted it and i am chuffed to bits with it
Tony
marco
Tony
marco
I'd go with what Brom suggests.
I polybushed the front end of my car, and I reckon unless you're a track driver, you wouldn't notice the difference between poly and new Ford rubber.
I love all these people who go on about how the polybushes tightened up the handling of their car, when the old rubber ones were 15 years old and perished
Richard, I am no track driver, I can't do a sequence of conrners without doing it sideways half of the time and I am pretty sure Powerflex does work. I've seen that on Imprezas (great effect) and shockingly good effects on Cossie front, although I still need to fit my rear beam poly mounts and check how they do.
I am interested though opn opisnion on uniball -> metal to metal connections on road car. I'm thinking about getting some bling stuff from Broom but will this be ableto bdo lets say 20000km's every year on road? Will the suspension or the chasis (or me) fall apart?
I think i will stick with poly bushes!!! got to get a set for the front and still not sure what to do with the rears yet........its very sloopy at the rear, any ideas what to do with the rear bushes i have heard so many different storys whats good and whats bad???????????????????
i have just bought some avo coilovers and want to do the right thing on the rear!!
why have you not fitted them to the rear beam????????????
Wonder if I could fit the beam ones without dissassembling whole rear.
why get them off cozymad is he cheap ???????
how do i get hold of him?
i to can vouch for cossymad his prices are more than fair just compare to the mags you wont beat him on price i dont reckon also quick delivery and a helpful service he da man lol
Originally Posted by Mr C
Marco Polo that must handle like a dream?? Sounds like a great chassis mod for greater handling.
Mr C
it does help , I have an early GRP A round beam solid mounted with rose jointed gravel spec trailing arms with Bilstein 909 magnesuim gravel spec coilovers with 16" springs ,rose jointed (top and bottom) one to the top of the turet and the other to the bottom of the traling arm
basically the back end dose not move at all , so that means the suppension has to work 100% properly
when you have got rubbers these move about so what happens the suppesion doesn't work that well because of movement
poly bushes do tighten up the car and they are better than standard ones
i have had all these set ups, i wouldn't ever got back to rubbers tobe honest
since have this set up the cars handles and turns in very well that i don't get any understeer at all ..i have took a few peeps out in the car since having the car set up and they were impressed for a rwd car
I have to admit that the cars is on it's limits for being a rd car this is why i will NOT go compression struts /Grp a ARB with drop links to the TCA's
some of you might think i bet the car i hard on the rd... it's not it's no worse than before when the car hits a bump the suppension absorbes the shock because it has the right springs for the right ride height and for the right (dyno spec) damping of the coilover this is where it gets tecnical LOL...
cheers Marco
This was on my previous EsCos - the guy I brought it off had actually had the antiroll bar and all front bushes replaced because of some movement/slack. When I bought it off him, I had the bushes done (Grp N, so not even poly ones), and let him have a drive - he was a bit sick
I fitted polyrace to the front of Saff and much nicer feel...i didnt need to do it as it was fine but they looked pretty in red in the RD catologue ...Highly recommended.
LISTEN TO MARCO HERE
i have a full deflex bushed car myself cos im a tight arse
if a) i could be arsed and b) had the will to, i would do exactly what marco has done
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
