FAO Plumbing type people
The shower tray in our ensuite has been draining very slowly recently and it's got to the point now where if you're in the shower for more than five minutes it overflows. What can I put down the drain in the shower tray to help it drain more freely? A guy at work said I can put bleach down there but I wasn't sure whether that was the right thing to do. I tried one of those foaming unblockers but it didn't seem to do much.
Ideas and opinions much appreciated.
Thanks!
Thanks!
Chasing Radders
Like has been said, you should be able to clean the centre out....
If not go to a plumbing merchants and ask for some GOOD drain unblocker...."One stop" ect and thuis is better than any of the stuff avalible from Homebase ect ect.....pour it down and wash away...Job Done
Our shower you can lift out the chrome plug hole bit then pull out a white plastic hook thing underneath which catches all the hair. You could also try unscrewing the shower head and use the pipe on full blast to shove down the hole and to try and clear any blockages.
Ours used to do it until I replaced the chrome plug hole bit for one of these;
http://cgi.ebay.co.uk/HAIR-TRAP-CATC...item3a5a6989e1
Stops all the hair going down the hole now and is a doddle to keep clean!
chowfornow
14
05-01-2019 09:01 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
