More boost please (or a least help me find where its gone)
Old 05-06-2010, 05:36 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
Default More boost please (or a least help me find where its gone)
or at least help me find the 8 psi I am missing
I fitted a recon(from cr turbos) turbo a few months back and ever since then the car has been down of boost had a good look round I dont have any air leaks so
could it be the new -31 actuator (from msd) (although it had a -34 before) I fitted at the same time or should I be looking else where
help me as I have a rolling road day in a ew weeks and I dont want to lose out the that old xr4i cossy rep
I am using a greedy boost controler not sure what one tho
Old 05-06-2010, 05:39 PM
bad boy rs
bad boy rs's Avatar
im down 5psi but i assume its down to the heat
Old 05-06-2010, 06:04 PM
martysmartie
martysmartie's Avatar
Did you preload the actuator before you fitted it?
Martin
Old 05-06-2010, 06:13 PM
KSA-Cossie
KSA-Cossie's Avatar
You have pm matt,will be tight between you and steve if the figure are anything to go by lol.
Old 05-06-2010, 06:15 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Im going first when its cooler
Bald one can go about 15th so the dyno cell is nice and hot
Steve
Old 05-06-2010, 06:25 PM
The cell is most likely temp regulated ?, still gives you time to pull off a plug lead from thier car ha ha!!
Old 05-06-2010, 06:29 PM
Captain500rs
Captain500rs's Avatar
Are you still using an amal valve?, mine was losing boost by about 5psi and it was the wiring for the amal valve.
Old 05-06-2010, 06:31 PM
KSA-Cossie
KSA-Cossie's Avatar
Steve
Like your thinking steve.
Old 05-06-2010, 10:46 PM
Matt Baxter
Back in black!
Martin
yeah its just over half a hole
Cheers for the pm Kev, gives me something to think about wont be happy if its the actuator but saying that its an easy fix would I be better off getting a forge one?
I know it wont make anyway near 400 atm with only 24psi a tired engine would be lucky to see 300
Steve
Its the only way you MIGHT beat me
its got a boost controler not sure if its still up to the job pretty sure its a greedy profec b
Old 06-06-2010, 06:09 AM
GUZZLER
GUZZLER's Avatar
put some more preload on the actuator or turn the gain up on the boost controller.
Old 06-06-2010, 07:23 AM
Jay,
Sponsor
Jay,'s Avatar
recheck for any leaks then fit a -34
Old 06-06-2010, 08:48 AM
Matt Baxter
Back in black!
already tried more preload and if anything it deopped a little and the boost controler is already at the max setting
Deffo dont have any leaks Jay as I made up a capped bit of pipe with a tyre valve in it and put it up to 15psi and it was holding that fine without any leaks.
So you reckon a -34 might be the answer?
if so what make should I go for as there are some fake Garrett ones about so i'm told
are the forge ones any good?
Old 06-06-2010, 09:00 AM
Jay,
Sponsor
Jay,'s Avatar
yeh forge one are ok mate or just by from a garrett approved stockist mate
Old 06-06-2010, 09:14 AM
bad boy rs
bad boy rs's Avatar
whats the advantage of a -34 ? ive only ever used a -31 with no prbs
Old 06-06-2010, 09:24 AM
KSA-Cossie
KSA-Cossie's Avatar
Gets my vote too jay.
Old 06-06-2010, 10:56 AM
S1
S1's Avatar
The -34 would have held more boost than a -31 so if nothing else has changed since fitting the -31 then surely there's bound to be a boost drop? I'm surprised you say the G-reddy is on its max setting, my Apexi AVC-rwill run mega amounts of boost. Not sure if its the same kind of setup but on the Apexi you dial in the boost level you require and drop the duty cycle to start with, then up the duty cycle until you reach desired boost level. Try adding more preload to the -31 before you replace it though.
Old 06-06-2010, 11:51 AM
Matt Baxter
Back in black!
Just ordered a Forge one from Burtons went for the 24-38psi one so just hope it sorts it out
Old 06-06-2010, 11:56 AM
Matt Baxter
Back in black!
THe greedy one is very basic tbh and had to be modded to make it hold 32psi by Talk of the devil
already tried adding more preload and if anything it dropped a little
anyway as i said above I had ordered a Forge 24-38psi one from Burton's so fingers crossed that will sort it out
Old 06-06-2010, 12:54 PM
KSA-Cossie
KSA-Cossie's Avatar
Fingers x'd for you matt.
Old 06-06-2010, 05:49 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Is your wastgate penny shutting correctly, the arm is not bent is it ????
Steve
Old 06-06-2010, 06:40 PM
Matt Baxter
Back in black!
Cheers Kev
Steve
I assume its all fine as it was new last year when the turbo was reconed, Ł700 in total told them I will be working the turbo quite hard so they pretty much replaced the whole thing
Old 09-06-2010, 02:59 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You found your boost ?????
Steve
Old 09-06-2010, 03:24 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
The -31 with same preload will lift approx 6 psi lower than a -34 so all you actually needed to do was increase preload by about 3mm to give an approx initial lift pressure the same as your -34.
Old 09-06-2010, 08:49 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Any news then my carbon flogging BALD friend
Steve
Old 10-06-2010, 04:39 PM
Matt Baxter
Back in black!
Steve
Nope
Cheers for that Stu although its a little late now as I fitted the new actuator and stilll only getting 26psi this morning, was only 24psi over the weekend but the weather was hotter then
So what next then???
Old 10-06-2010, 04:44 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Check the wastegate is sealing 100%, im sure thats all that was wrong with mine
Stu21 put a bit of paint around his penny valve to see how well it sealed as he had lost some boost
Steve
Old 10-06-2010, 04:49 PM
Matt Baxter
Back in black!
Steve
Yeah thinking I should just wip the turbo off and pop it down to cr turbos and get them to check it out its done 2k max
just hope what ever it is its an easy fix
Old 10-06-2010, 04:51 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Best you sort it or the cossie wanabe will beat you
Steve
Old 10-06-2010, 05:07 PM
Moonstone Steve.
Moonstone Steve.'s Avatar
Steve
You hope
Steve
Old 10-06-2010, 05:49 PM
gibbo frst
gibbo frst's Avatar
ive known 2 people recently one with a brand new t34 and one with t38 both have had bent or not seated wastgates/arms.. and another with a group a t34 that wont make more than 25psi no matter how tight the actuator is.. he had the arm repaired twice already..
Old 10-06-2010, 05:54 PM
gibbo frst
gibbo frst's Avatar
mine also went back once as wouldnt make more than 25psi and turbo technics said it would be fine as had the inconnel arm so i used a paint pen around the penny and shut it tight then when opened it hadent sealed properly .. they had to fix it again...
Old 10-06-2010, 09:33 PM
Matt Baxter
Back in black!
well thats made my mind up the turbo will be coming off and going back to get checked out Cheers
Old 16-06-2010, 04:08 PM
Matt Baxter
Back in black!
Right got back from CR Turbos just now and refitted the turbo with new washer, arm etc and its still the fucking same the only other thing thats changed is it was a spare t34 that I used to get reconned but as it had pretty much all been replaced I cant see that being the problem oh and its now got a 70mm cooler from A.S.
thought I had found the problem going by the marks on the washer
Anybody got any more things to check/Adjust
Old 16-06-2010, 04:10 PM
Matt Baxter
Back in black!
just to add that I have tried more preload and it made fuck all differance
Old 16-06-2010, 07:24 PM
LHD220Turbo
LHD220Turbo's Avatar
have you got the old amal valve you can try just to try it and rule that out
Old 16-06-2010, 07:39 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I hope you sort it Matt
Try changing back to the intercooler you was using ???
Steve
Old 16-06-2010, 08:46 PM
space hoppers
space hoppers's Avatar
sheady told me the forge actuaters are pants buy a genuine garret -34
Old 16-06-2010, 08:51 PM
Matt Baxter
Back in black!
Dont they need modding to up the boost tho?
Steve
So do I mate
cant try the old cooler as I got rid of it as it was leaking starting to think it could be the boost controler so gunna try a bleed valve see what that does
Old 16-06-2010, 08:58 PM
Mark Shead
Mark Shead's Avatar
So do I mate
Have you pressure tested the inlet system.
Mark
Old 16-06-2010, 09:08 PM
LHD220Turbo
i didnt need? to but i've seen people enlarge the holes a little
id try it just to rule it out
Quick Reply: More boost please (or a least help me find where its gone)
