just corner weighted the 5, results.... any suspension gurus care to comment?
#41
the way my arb is fitted on the 5 is it bolts to the bottom of each wishbone and at 2 points across the subframe, i cant remove this without a lot of work. (i have to jack the whole car up a long way and remove my false floor plate, thats riveted on. so not a small job)
i might redo it later over a weekend when i have more time to play, but for now this has to be better than it was.
i was doing it last night after work so didnt go too mad.
also i used to get a lot of wheel spin from the drivers rear wheel. having 150kg less than the passenger side might have been the reason for this.
now they have a more even spread of weight im hoping to get less spin.
#42
well ive been out in it tonight and....
the mad wheels spin from the driver side is near enogh gone.
it still spins, but nowhere near as much. so i must have done something right. lol
now i just got the rest of the problems to sort out.
#47
*** Sierra RS Custard ***
Moving weight inside the car is exactly how I would expect to have to make the sort of massive change that stu has made, I wouldnt expect it to be possible on spring platform height alone without it being changes too big for the car to sit looking level anymore and hence it would mess up suspension angles.
#51
Are you doing the geometry on tonights night shift then?
#52
It looks fine, but I'm not too fussed how it looks tbh.
From memory the passenger side was 25mm higher than the drivers side, now they are within 5mm of each other.
The passenger front has dropped 10mm ish and drivers side not too much.
I'm not doin it this weekend. Working tomorow and a christenin on sun.
Might take the arb off the front and re weigh it all, then measure up and redo the geometry and check rates next weekend.
The most important thing for me to do at the moment is sort out my gear change. I'm having loads of problems with that. And it's costin me loads of time to change gear meanin I watch people drive away from me due to slow changin.
#53
Its fairly easy to change the suspension by 100kg's per wheel or something. For example if you have 10kg per mm springs. and you lower that wheel 1cm, you'd have 100kg's extra as that wheel would be under 1cm more preload. In reality though and I guess what your getting at is the other 3 wheels all change there weight and it becomes a real PITA.
I've actually done something very similar in the past, be carefull not to change the settings of each corner by more than a couple of CM as you'll make it worse. This also assumes the chassis is 100% stiff, jacking it up then letting it down its suprising how much twist you get sometimes.
#55
wowk
30-03-2021 07:49 PM
SMILER258
28-09-2015 09:04 AM
