Help needed, not holding oil pressure
Old 24-05-2010 | 09:00 PM
Daniel Clement rs turbo's Avatar
Exclamation Help needed, not holding oil pressure
Hi lads, I've just put a engine into my frst, doesnt seem to hold oil pressure, oil light came on wen I started da car, it said it's about 11psi on da gauge at max and wen I rev it it goes up to 25psi maybe more and the oil light goes off, took the oil feed off the turbo and it just splutered out oil.. I've put a oil cooler kit on too and hav made sure to keep the air locks out.. Does anyone have any tips that will help me find out what the problem is, p.s. It seems to pump oil fine as checked it for that.. Thanks lads..
Last edited by Daniel Clement rs turbo; 24-05-2010 at 10:25 PM. Reason: Because I can
Old 24-05-2010 | 10:28 PM
Anyone have any idea what wrong with it?
Old 25-05-2010 | 09:46 AM
Bump up
Old 25-05-2010 | 10:02 AM
Jasesapphy's Avatar
Jasesapphy
11psi is not enough buddy, could be a number of things, if its been run on that oil pressure the engine will be knackard
Old 25-05-2010 | 07:32 PM
Ye I know that's why I need help quick, no1 knows what's going on.. Yet when I rev it up the light goes away.. Do you think I need to upgrade the oil pump to cope with the oil cooler and it's big pipes.. Like the gauge and the standard switch couldn't be both wrong, worked fine in the old engine just that cyl 4 low compression..
jessie_rs
11
03-06-2019 04:57 PM
Chas
21-09-2015 08:57 PM
Zoggon
10-08-2015 10:39 AM
Roosie
09-08-2015 07:37 AM
col93saphcos
07-08-2015 03:21 PM
Quick Reply: Help needed, not holding oil pressure
