feista turbo over fueling
i have a feista turbo engine in my mk2 feista but all it dose is over fuel all the time even on idle
it was running on beiges, with a t3 and a 195 chip on ofab with a std cossie pump but it was just overfueling badly. to the point it killed a set of brend new plugs so just to see if it would sort it out i took the chip off and put the blues back in and a new set of plugs and it starts up better but stil is overfueling badly. ive tried turning the ragulator up down but it dont make a difference to it. even when you bring it on boost its still way too much and ideas would be very helpful
I would try changing your fuel pressure regulator. I have a similar setup and this was the cause of my overfuelling. I got mine from a local motorfactors for about £50-£60 which supplied the same webber item thats fords would supply for about £180. Sorted mine out. HTH
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
