Mk3 cortina help
HELLO all [/B], first time on the forum and need a bit of help please , im currently in the process of restoring my farther in laws 1972 mk3 cortina L saloon only ive hit a snag, i can only seem to find on the internet a master cylinder with three outlets this mk3 has only two pipes , there is one to rear and one to passenger side chassie rail connected with a flexi , then it splits off to the drivers side front via the crossmemebr, is this correct or a bodge from past years , hope you can help , can send pic if wanted
john
john
just spoke to him and all mk3 cortinas had 2 pipe master cylinders. late mk4 and all mk5's had 3 pipes. he thinks he may have a used 2 pipe one in his garage and will look later on.
you can use the 3 pipe ones and just blank one of the outlets off,but all the outlets on the 3 pipe ones are for 10mm unions where as the original 2 pipe ones are one 10mm and one 13mm. or you can use a 3 pipe one and just run 2 seperate pipes to the front calipers.
he said the best place to look for bits and advice is on buy sell cortina.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
