AP Racing CP5555 6 pot fit ???
Originally Posted by wimwerf
cp5555 arent for 300mm discs.....
and the ET from the escos alloy are a problem i think
No room behind them - look at the clearance for the standard sliding calipers - a nat's cock, so no chance of AP 4-pots let alone 6-pots.
Hi-spec do a special slimline 4-pot caliper and 310mm disc that will fit behind the standard wheels though...
how much is the hi-spec kit mate !!
Originally Posted by Smit
After the hassle thrown about on here for high-spec i'd think again
Grants having a nightmare at the minute with them!
Same problem - no room . Ditch the Escort Cosworth wheels and the world is your crustacean....
cheers mate !!!
Originally Posted by tiny
911 turbo callipers ( brembo ) fit under esc cos rims on standard 283 mm
discs, they arnt a straight bolt on fit though. you would have to have the
hubs fettled,
hubs fettled,
No m8 sorry there on the car but i can confirm they are very very
good. I had ap 4 pots on my last car, and these are every bit as good if not
better imo , the calipers are very large compared to the cozy ones, and the
piston / pad size is nearly twice that of the cozy ones, basicly i wanted the
best brakes i could fit under 16 inch rim, and im well pleased with the end
result.
result.
track.focus'd
12-08-2015 05:53 PM
